Go Back   Airstream Forums > Airstream Marketplace > The Vendor's Forum
Old 12-04-2006, 04:50 PM   #1
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Back-up Monitor for Travel Trailers.
Perfect for this Christmas
Never be blind again.
FINALLY a wireless back-up monitor system in color for travel trailers. No wires needed between the camera and monitor.
The camera mounts on the license plate bracket and ties into the back-up OR license plate light circuit. It's so small no one will realize it's there. The monitor is placed on the tow vehicle dash and plugs into the 12 volt outlet or cigarette lighter.
We recommend that you tie the camera into the license plate light circuit.
When traveling, turn your parking lights on, so that you can continuously monitor who is behind you. When you're ready to back up, the monitor is still working.
When you park, shut the lights off and you will not have any battery drain.
We tested this system by having the camera 150 feet away from the monitor, certainly far greater distance than from the dash of your tow vehicle to the license plate on the trailer. The monitor displayed a perfect picture.
Christmas special, $139.95, plus shipping.
Best new safety item since load equalizing hitches.
Part # 78000.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 12-04-2006, 05:11 PM   #2
ticki2
Profile:  1976 25' Caravanner
Campton , New Hampshire
That sounds like a pretty neat gizmo . Can the camera be taken on and off easily so it could also be used on the TV for backing up to hitch up ?
ticki2 is offline   Reply With Quote
Old 12-04-2006, 05:38 PM   #3
tslanier
Profile:  1998 34' Excella 1000
Jamestown , North Carolina
Tire pressure monitor!
Do you have a recommendation for tire pressure monitors?
98 34' Excella Classic
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch
WBCCI #4358
tslanier is offline   Reply With Quote
Old 12-04-2006, 05:47 PM   #4
Ed Keyes
BAUXITE
Ed Keyes's Avatar
Profile:  2004 25' Classic
homosassa , Florida
Back up monitor
Andy, can you show how it was mounted ?
BAUXITE
Ed Keyes is offline   Reply With Quote
Old 12-04-2006, 06:11 PM   #5
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Thanx Andy, I've been looking for something like that.
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 12-04-2006, 06:43 PM   #6
Commercial Vendor
You would have to have another mounting and another 12 volt wire.
Inlandrv.com
Old 12-04-2006, 06:47 PM   #7
Commercial Vendor
It mounts to the top of the license plate bracket as shown in the following photo.
It's the black horizontal bar.
Inlandrv.com
Old 12-04-2006, 08:20 PM   #8
SteSpot
SteSpot's Avatar
Profile:  1968 28' Ambassador
Venice , California
Do you mean to drive with your headlights on instead of your parking lights? pj
Suite Spot
WBCCI # 22353 Air#13593
1968 28'Ambassador
SteSpot is offline   Reply With Quote
Old 12-04-2006, 08:22 PM   #9
Commercial Vendor
In the day time, you can use your parking lights or headlights.
At night time, best you use your headlights.
Inlandrv.com
Old 12-04-2006, 08:54 PM   #10
68 Overlander
Commercial Vendor
Profile:  Boise , Idaho
Images: 21
Andy,
That is a neat system and affordable.
Old 12-04-2006, 08:59 PM   #11
soldiermedic
soldiermedic's Avatar
Profile:  1975 29' Ambassador
1953 21' Flying Cloud
O'fallon , Missouri
Sold at Wal-Mart
For under $100.00.
http://www.walmart.com/catalog/product.do?product_id=4744711
soldiermedic is online now   Reply With Quote
Old 12-04-2006, 09:01 PM   #12
SteSpot
SteSpot's Avatar
Venice , California
Parking lights
It is illegal in California to drive at any time with only parking lights on.
http://www.chp.ca.gov/html/militarydrivers.html. It is best to use your headlights all the time--just took a driving class and don't ask why.pj
Suite Spot
1968 28'Ambassador
Old 12-04-2006, 09:24 PM   #13
2airishuman
2airishuman's Avatar
Profile:
We tested this system by having the camera 150 feet away from the monitor, certainly far greater distance than from the dash of your tow vehicle to the license plate on the trailer. The monitor displayed a perfect picture....Andy
thanks for the product info andy...
i've been looking for this sort of product a while...
150 ft would be GREAT, but according to the vr-3 website...
transmission is 9 meters, about 19 feet...
was your testing 'open space' or through the trailer/tv...
perhaps an upgraded model?
i need 55-60 ft.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 12-04-2006, 10:17 PM   #14
Jim Clark
Jim Clark's Avatar
New Orleans , Louisiana
i need 55-60 ft.
cheers
2air'
I have one; I haven't tested it on the road yet. It dose transmit from the inside of the trailer to the monitor. I soldered a 12 volt plug in and use the voltage in the trailer. I think I may cut off the license plate mount and a little Velcro will let it be used for many things. Security camera, ball alignment camera and so on. I plan to attach in the back window so it is out of the weather. I may open the unit and add a different antenna. I did get some interference at about 35 feet and 150 feet would be on the far side of the range. Pep boys have the units for $99.00 after rebate. I will bring it to Topsail.
BTW you don't want the 2 button model the one I have has power, contrast, brightness, and 4 postion image flip so 4 buttons.
First Weekend Shindig @ Topsail First Weekend in Jan.
Thanks Jim, N5TJZ
2005 25' Safari ,AIR# 174
S/V Wandering Spirit
http://airstreamlife.ning.com/profile*/JimClark
Picture Gallery
http://gallery.mac.com/jimclark6#gallery
Jim Clark is offline   Reply With Quote
Homemade backup camera 83Excella Airstream Trailer Forums 28 08-17-2005 12:31 PM
Argosy trailers 83Excella All Argosy Trailers 33 07-20-2003 10:43 AM
Production Numbers on Front and Back? Guitars WBCCI Forum 5 11-24-2002 08:47 AM
Tear Drops !!!!....... canny_banjo_man Our Community 13 08-19-2002 12:49 PM
First Time Buyers Sheri On The Road... 5 07-08-2002 08:09 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
