Go Back   Airstream Forums > Airstream Marketplace > The Vendor's Forum
Closed Thread
Old 04-29-2003, 09:27 AM   #1
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Air Conditioner pans
Carrier makes a 15,000 BTU Roof AC, that would work great for many owners.
The basic problem is that a drain pan at this moment does not exist.
However, we are working on a small inexpensive pan kit, that is made out of fiberglass.
We would like to know how many might be interested in this new developement.
inlandrv.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Inland RV Center, In is online now
Old 04-29-2003, 10:26 AM   #2
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Would it only work on Carrier units?
>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Action is offline
Old 04-29-2003, 11:04 AM   #3
Commercial Vendor
Each type or brand AC has it's own unique base.
The Carrier AC pan, will only fit it, at least hopefully, by the time we are done with the R & D.
The idea here is that the Carrier is very light compared to others, and has some special features that none of the others have.
More later. Bench testing etc, is now in progress.
inlandrv.com
Inlandrv.com
Old 04-29-2003, 11:13 AM   #4
j54mark
Profile:
I would be interested in hearing some of the advantages Carrier offers. If at all significant, it would not take all that much to get me to replace my noisy, ugly, and (I suspect) inefficient Coleman.
Mark
j54mark is offline
Old 04-29-2003, 12:50 PM   #5
Action
Moderator dude
Action's Avatar
Phoenix , Arizona
Images: 13
More Q's
Andy,
15K BTU is a strong unit.
Any idea of what the total weight of the Carrier might be? And the height with the drain pan?
Also, if an older unit (say an early 60's) did not have A/C originally, could the Carrier be made to work? And how would the drain pan direct the condensate? Over the side?
>>>>>>>>>>Action
Action is offline
Old 04-29-2003, 05:50 PM   #6
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
andy
i havent looked at the carrier because it does not have a drain pan avail. what are the specs for the carrier unit your making a drain pan for ?? i really want a efficient unit on top of the silver weenie that doesnt load my gen set to the max. was looking for a pan that would work on the coleman power saver. it is a 13500 btu unit that only pulls 10 amps. lol
al
wb13798 is offline
Old 04-29-2003, 08:51 PM   #7
LLB21
LLB21's Avatar
Profile:
Carrier is certainly a good name in home air conditioners.
I believe that the Carrier RV air conditioners are developed to handle condensation differently so it does not run down the sides of the trailer.
The only problem I had with them is that they are boxy looking and not as sleek looking as Dometic.
Louie
LLB21 is online now
Old 04-30-2003, 03:06 PM   #8
JPAIRSTREAM
JPAIRSTREAM's Avatar
Profile:  1972 31' Sovereign
, Ohio
Images: 47
SPEC PAGE for various models of A/C's.
Not sure of pricing but Airstream has pans for the dometic A/C's 13,500 and 15,000 btu's according to there parts book..... There Duo-therm's Penguins with heat pumps..
Here is another link to the point about the condesation control..Manual from Carrier
I have also found that a Carrier AIr V weighs approx 90lbs.. still looking for dometics weight..
JP
JPAIRSTREAM is offline
Old 04-30-2003, 03:34 PM   #9
1985air345
airstreammotorhomes.com
1985air345's Avatar
Profile:  Charleston , West Virginia
Airstream only offers a pan for the Duo-Therm Penguin which is not the high efficiency model from Duo-Therm. they are shorter by 3 inches (9"vs 12") so the wind drag is less while moving.
I have heard that the Carrier unit is loud. My Colemans aren't exactly quiet!
I guess the interest in Carrier is the Carrier name and reputation and the cost which is usually $150 less for a similar 15,000 BTU unit.
I too am concerned about the load on the generator. My two old Coleman's said 20amp under the cover when I took the shield off. I am assuming that 2 new 15 amp units will be easier for the generator than the old existing 20amp units. (FYI - I have the 7k Kohler generator)
Fred H.
No Airstream Anymore..
Fred's Airstream Archives - Motorhomes
Fred's Airstream Archives - Trailers
1985air345 is offline
Old 04-30-2003, 06:46 PM   #10
Chas
Chas's Avatar
Profile:  Austin , Texas
Images: 22
The Carriers probably sling the condensate water up onto the condenser coils much like a lot of residential window units. Very efficient but a bit noisy. You can tell on the window units, you can hear it sloshing up, sizzling and hissing nonstop.
I am not sure if you can hear it on the Carriers.
Chas
Chas is offline
Closed Thread
Air conditioner thermostat working? nickcrowhurst Furnaces, Heaters, Fireplaces & Air Conditioning 7 03-18-2004 07:37 PM
Air Conditioner Draft w9det 2001 Safari 11 09-01-2003 10:01 AM
Air Conditioner Question/Problem??? pscottn Furnaces, Heaters, Fireplaces & Air Conditioning 6 08-23-2003 10:21 AM
For Sale 13,500 BTU Air Conditioner GoldFever Parts Archive 4 08-09-2003 09:11 PM
Heater and Air Conditioner Jeb Airstream Motorhome Forums 2 10-22-2002 07:45 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
