Old 04-20-2010, 03:07 PM   #29
Central , Mississippi
A bunch of hot air
(said in a winey voice) "My 22 ft Airstream with a 15k BTU AC won't stay cool, what do I do?"
Hey buddy, try a 13.5K BTU on a 34'er!
We struggled with a 14k BTU on our 29' so I already know that this one will be unacceptable in a matter of a few weeks, sooooo....
Time to install a second ac unit.
As usual, I listened to advice then went and made up my own mind - that goes completely agains all the advice...we will be sticking in a 11k BTU penguin low profile. Out goes the bedroom fantastic fan (it's gonna get relocated to somewhere) and in goes the penguin. As of right now - that's the only details I have worked out! I gotta run a second breaker box, a second shore power line and get a drain line snaked thru the hull.
The first steps were to order the unit, then realize I need a way to get it off the truck - so I gotta build some forks for the front loader...
A couple of weeks later a big truck pulls up and I have big boxes that say Dometic (upside down if you notice).
More later (hopefully)
ID:	100775   Click image for larger version
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 04-20-2010, 03:09 PM   #30
here's what is inside the expensive boxes
Inside the biggest box is the main unit, the smaller box is the inside air distribution portion/controls . They are ordered separately...hummm, the next step is to shove all the stuff in the garage and....go camping...
ID:	100778   Click image for larger version
Old 04-20-2010, 05:02 PM   #31
_
so u r gonna ac the shower stall and the head ?
that'll b a real meat locker...
"no really it's shrinkage, you've heard of shrinkage?"
i like it!
but won't the ac be sorta slanted in that roof location ?
and what's the plan for fart gas evacuation?
could need a LOT of matchesncandles...
cheers
2air'
Old 04-20-2010, 05:11 PM   #32
Ag&Au's Avatar
Port Orchard , Washington
He said bedroom fan not bathroom, but your version makes better copy.
i like it!
cheers
2air'
Old 04-20-2010, 05:25 PM   #33
i like it!
cheers
2air'
I guess some additional details would be in order...
I'm kinda thinkin about puttin the Fantastic Vent in the poot room. That way I can leave off the screen and toss toilet paper in the fan, spittin confetti out the roof and into the campground....
But...
The AC is looking like it needs to go in the bedroom...
ID:	100803   Click image for larger version
Old 04-20-2010, 06:30 PM   #34
_
ok so the bedz going in the bathroom too?
that's gonna be one crowded, cold latrine.
and hows that penguin gonna use the toilet from way up there?
they make a pretty big chunk o'droppings.
the F'fan sans screen makes a mighty fine salad shooter.
nevamind...
cheers
2air'
Old 04-22-2010, 05:04 PM   #35
Today when I got home there was this nice size box that says 'From Out of Doors Mart'
And inside is a Airstream/Penguin drain pan.
ID:	101057   Click image for larger version
Old 04-25-2010, 07:08 PM   #36
We spent the weekend camping at a local park and even though the temp was only in the 80's the rear bedroom was uncomfortable. So this afternoon I parked the 'Stream in the driveway, grabbed a ladder and started preppin for the rear AC install.
1st order of business was to remove the Fantastic Fan . all of the screws were covered in sealant goop but they still managed to rust. Vice grips to the rescue...slowly twisting out each one...1/2 a turn at a time .
So I have to get 110V and a drip line up here...the plan was to route them thru the roof and into the bathroom. From there I could exit the roof and come down the corner beside the vent stack (its hidden behind the medicine cabinet and some trim). Then I can cross behind the toilet and into the sink cabinet. The drain can drop thru the floor and the 110V can route back to a bedside cabinet where a new breaker box will be installed.
ID:	101300   Click image for larger version
ID:	101302   Click image for larger version
Old 04-26-2010, 08:33 PM   #37
Tonights goal was to get the support framing in place. I matched the curve of the Drip pan onto a piece of 1" thick scrap, then transfered it to a 2x4. The ceiling is 2" thick so the same curve, 2" away, is the basic shape for the from and rear pieces with the length of 14.25" The side pieces need a slight angle to the top and bottom so the would sit flat. They needed to be 17.25 long for a proper overlap on the front and rear segments.
ID:	101358   Click image for larger version
ID:	101360   Click image for larger version
Old 04-26-2010, 08:35 PM   #38
The street side has 2 holes added for the power and drain lines. The interior of the AC overlaps the bedroom light switch so it had to be moved 2" forward. Lots of screws and the wood is in. When the moon comes up its time to tape the vent cover back in place and call it a night
ID:	101362   Click image for larger version
ID:	101364   Click image for larger version
Old 04-29-2010, 07:20 PM   #39
rain
The weather man says rain tomorrow so I figgered I better sneak outta work a bit early and get the hole in the roof plugged. I covered the wood inserts with aluminum tape, caulked the drip pan in place then lifted the AC unit up, up, and away.
ID:	101540   Click image for larger version
ID:	101542   Click image for larger version
Old 04-29-2010, 07:22 PM   #40
Cool Dude
An a couple of hours later...
blowin in the wind is cool air...
It's running on temp power so I can see if the drain is gonna drain...
So far- so good
ID:	101544   Click image for larger version
Old 04-29-2010, 08:30 PM   #41
Mexray's Avatar
1978 28' Ambassador
Morada , California
Those of us with vintage AS's probably need a tatoo across our 'broad' shoulders that says,
"Get an Airstream, and the fun never ends...."
Ray
Ray & Pat; Morada, CA
Old 04-29-2010, 08:31 PM   #42
_
looks good bud!
and you just love playing with that tractor...
cheers
2air'
3955 miles FordTruck On The Road... 2 07-06-2009 11:12 PM
Actual Miles Dr.Theopolis Argosy Motorhomes 2 07-06-2009 09:41 AM
Hours vs. Miles FordTruck On The Road... 6 06-15-2008 08:30 AM
TORNADO - 5 miles away and closing clancy_boy Off Topic Forum 19 10-22-2007 10:53 PM
Miles per Gallon? Phil Gobie On The Road... 52 12-21-2006 06:56 PM
