Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella 1000 > 1993 Excella 1000
Old 08-16-2003, 12:39 PM   #1
norbert
norbert's Avatar
Profile:  1993 30' Excella
chicagoland , state of confusion+north of cheddar curtain
Images: 24
leaky water tank etc.
my recently purchased 93 excella 1000 30' was found to have a cracked(3) water tank( guess thats one of the reasons the old curmudgeon sold it )...local shop called airstream...dont make any more... they are searching.... anybody got an idea?... also the 2 piece lugnuts were worn and a bear to take off... just replace with standard lugnuts?
noby...
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 08-16-2003, 06:17 PM   #2
j54mark
Profile:
Call Airstream yourself, direct. I find it hard to believe there is no factory replacement. Or call Andy at Inland RV (http://inlandrv.com/).
Failing that, there are several companies that manufacture new tanks to your specification. It will take some research on the net, but they are out there.
Good luck,
Mark
Old 10-22-2003, 02:25 PM   #3
James Schmidt
Profile:  1993 29' Excella
Jonesboro , Louisiana
noby,
My lugnuts were giving me a problem too. The aluminum cover was bent out of shape about the second or third time I took them off. I just replaced them with regular lug nuts and had no more problems. Good luck with the water tank!
James Schmidt
29 ft Excello 1000
97 Expedition/Hensley Hitch/
McKesh mirrors
James Schmidt is offline   Reply With Quote
Old 10-22-2003, 03:05 PM   #4
nellie the elephant
nellie the elephant's Avatar
Profile:
This stuff was recommended to me for a leaky tank:
http://www.prosealproducts.com/PS34.htm
Nellie
nellie the elephant is offline   Reply With Quote
Old 10-22-2003, 03:22 PM   #5
74Argosy24MH
Profile:  LOST , Hawaii
You can try Inca Plastics for a replacement for your tank.
John
74Argosy24MH is offline   Reply With Quote
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 08:16 PM
fresh water tank filling system nickcrowhurst Fresh Water Systems 5 03-16-2004 12:37 PM
Leaky fresh water tank nellie the elephant Fresh Water Systems 3 10-13-2003 02:12 PM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
