Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1984 - 1989 Sovereign
Old 07-01-2011, 06:05 PM   #1
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
Origional TV antenna, any value?
I just installed a new 'bat wing' on the 'ol girl. the original looks fine but was just bound up with age and oxidation I guess. I saved the old one in case there is a "purist" out there that would want it. Is this something that is desirable to anyone? I'm a newbie and have no idea. I would post to 'classifieds' but I have no clue to a value (if any). Can you help?
Matt
captmatt is offline   Reply With Quote
Old 07-01-2011, 06:23 PM   #2
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
I say post it in the classified's. Don't ask too much or you'll be stuck with it forever. I once had a dinette set sitting in my garage for 3 1/2 years. No one would buy it, I guess because shipping it would have cost an arm and a leg. Once I posted it "for free" someone came and picked it up. Good luck.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 07-01-2011, 06:51 PM   #3
toastie's Avatar
1955 22' Safari
Great Lake State , .
Matt
Could you post a picture............thanks
toastie
toastie is offline   Reply With Quote
Old 07-02-2011, 12:37 PM   #4
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
photos
I think I attached some photos, new to this sites format, we'll see! The antenna works fine now that it is off the AS!?!
Old 07-02-2011, 12:46 PM   #5
Martinez , California
I'm guessing that the real problem was the electrical connection to the cable or twin lead.
Mr.Bill is offline   Reply With Quote
Old 07-02-2011, 01:12 PM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Those work great and parts are readily available. I'm sure someone will want it.
Vaughan
Old 07-02-2011, 02:21 PM   #7
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
No, my issue was the mechanism was jammed. Coaxial could be bad, I just don't know... I'm in 'renovation' mode and have not gotten to the "install T.V." stage so I don't know if the cable was good or not (so I replaced in anyway!). It functions fine now, I guess it was just idle too long and didn't want to budge. Problem solved and now a vintage antenna is on the market!
Old 04-19-2012, 04:16 PM   #8
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
Found the person in need of the antenna and he was in England. Shipping took some work but it will be part of a true 'original' A.S. in the UK. Not easy to pull off... very admirable, I look forward to pics.
Old 04-19-2012, 07:46 PM   #9
1983 34' Excella
1967 24' Tradewind
Images: 32
Good for you.
Those antennas work great. I'm sure they will be pleased.
Vaughan
Old 06-23-2012, 06:16 PM   #10
1986 29' Sovereign
Los Altos Hills , California
In reply to CaptMatt's post of almost a year ago:
How did you install the new coaxial cable? Is it possible to use the old as a pull wire to pull in the new?
I have a 29' Sovereign the same year as your 31', and am replacing the TV antenna with a Ham radio 144/440 antenna. The new antenna uses 50 ohm coax which is slightly smaller than the existing 75 ohm TV coax.
The TV antenna is available if anyone wants it. Just take it away.
jealtstatt is offline   Reply With Quote
Old 06-24-2012, 04:54 AM   #11
rogerdodger's Avatar
1974 Argosy 28
Fresno/Clovis , California
Hi jealtstatt. Welcome to the forum. I installed a 2 meter antenna on my '81 Excella, attached it to the refrigerater vent, ran the 50 ohm line down the vent, out the wall to my rig in the living area. When I sold the Excella, it was an easy remove.
Roger
rogerdodger is offline   Reply With Quote
Old 06-05-2013, 08:08 PM   #12
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
Had it done by "pros" wish I could help...
Old 06-05-2013, 08:17 PM   #13
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
BTW the original antenna made it all the way to the UK. A gent' there was keeping it as original as possible. Great story of how it made the journey, basically he covered my shipping costs and his family filled in the gaps. I hope to see a photo some day. (And I complain about a leaking holding tank... I need to just calm down here.)
