Join Airstream Forums Today
Old 03-06-2011, 09:40 AM   #1
Alderman's Avatar
1966 20' Globetrotter
Chesterfield , Virginia
Window seals and clips for '66-'67 globetrotters
It appears that the window seals and window clips are somewhat unique for 66-67 Globetrotters. The glass have no metal frame, it is secured by metal clips at the bottom, and the seals are applied directly to the glass. I want to replace the seals and the clips, but am likely to have an ulcer for lack of instructions or tips on going about it. Your comments (other than "good luck, sucker!" are greatly appreciated!
Alderman is offline   Reply With Quote
Old 03-06-2011, 10:13 AM   #2
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Alderman,
Go to Vintage Trailer Supply.com as they have a variety of those clips to suit all of the various configurations. Trailers with original glass are one size, original glass with SS trim is another, modern glass is another & of course modern glass with SS trim is another. Simply bending clips that are too large to begin with can be problematic.
Colin
Colin H is offline   Reply With Quote
Old 03-06-2011, 10:37 AM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
These windows are also called "Corning windows" and the mechanism that holds the window closed are Phillips(no replacement that I know of).
Name:	Airstream manual 86.jpg
ID:	123777   Click image for larger version
Name:	Airstream manual 87.jpg
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 03-06-2011, 11:00 AM   #4
The seals (gaskets) were never applied to the glass.
They were always attached to the window frame, wich is the part that is riveted to the shell.
Also, there is a far superior gasket upgrade that is avalable.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-06-2011, 08:03 PM   #5
Alderman's Avatar
Thank you. The info noting that the gasket was not supposed to be attached to the window glass is a bit unsettling. I guess someone did a boo-boo on mine. I am amazed that I don't have more than the two minor leaks that I do have. I appreciate your input.
Old 03-08-2011, 05:24 PM   #6
Alderman's Avatar
You have been a tremendous help. I have two more questions for you.
1- I am interested in the up-graded gasket, where is a good source?
2- Will I need to remove the glass to install the gasket?
Thanks in advance!
Old 03-08-2011, 06:54 PM   #7
clancy_boy's Avatar
2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Thanks in advance!
Inland RV has the gasket and so does Vintage Trailer Supply.
No - you will not need to remove the glass to install the gasket. Do not use steel wool to clean the area - steel fragments will get into the aluminum and discolor it later when it rusts, use brass wool. VTS has the new upgraded clips for your windows. Mechanisms for the openers are a premium and hard to find.
Michael, Tina & Layla BZ
1966 17' CARAVEL LUCY
2003 22' INTERNATIONAL CCD DESI
Old 03-08-2011, 08:09 PM   #8
airstreamjudy's Avatar
1968 24' Tradewind
Largo , Florida
I purchased my replacement (missing) windows from Inland RV and they also had gaskets.
JudyW
airstreamjudy is offline   Reply With Quote
