Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Bambi > 1999 - 2004 Bambi
Old 05-06-2008, 01:24 PM   #1
mrtorian
Profile:  1999 19' Bambi
TV & Mounting Options Needed Please
Hello all. I have a 1999 19-footer, and I need to get a tv installed before the summer. My plan is to mount it on the wall facing the rear bed with a bracket that swivels to the front so folks at the table can see it. Insofar as the TV goes, it'd be nice to get one with internal DVD.
Any and all help will be much appreciated.
-JD
mrtorian is offline   Reply With Quote
Old 05-06-2008, 02:09 PM   #2
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
Check this place out and click on components. You can customize for just about any need
RAM Mounting Systems, Inc.
Old 05-06-2008, 02:20 PM   #3
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
-JD
TV - One with an internal DVD is great and a space saver but when the DVD goes out then you still have to have one to play a movie. We have a nice 17" LCD from WalMart for under $100 and it works great with the portable DVD player we use in the truck while on the road.
MOUNTS - check out the mounts that SAMS or COSCO sells for around $100 or less. Just make sure the surface you mount to is not all particle board and back it up with a metal plate or large washers on all the screws.
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 07-13-2008, 09:47 PM   #4
mrtorian
I haven't been on here in a while, so I am surprised this is still the top post. Anyway, the TV has long since been mounted. I used a Sanus 15.5 inch mount connected to a beautiful 19" Samsung TV (model #LNT1954H). Both perfect fits.
hook-up options for a 50 amp service nyulman Electrical - Systems, Generators, Batteries & Solar 4 01-13-2007 09:45 AM
help & advice needed in the UK merpb Classic Motorhomes 4 09-29-2006 10:20 AM
Satellite radio antenna mounting & wiring silverback Electrical - Systems, Generators, Batteries & Solar 6 11-14-2004 06:24 PM
2004 Airstream Classic Interiors & Options Craftsman 2004 Classic 3 04-30-2004 07:24 AM
Peters & Russell parts needed JimC Water Heaters, Filters & Pumps 2 04-14-2003 07:00 PM
Forums Directory
