Old 07-01-2003, 09:55 AM   #1
campcollector's Avatar
2003 19' Bambi
Lincoln City , Oregon
Images: 21
Question Tongue/frame Paint
Can anyone tell me what the factory tongue and frame paint color and type was/is being used on the 2003 and current A/S trailers? And is there an equivilent spray paint product in that color such as Rustoleum/ Kryolon etc?
campcollector is offline   Reply With Quote
Old 07-01-2003, 11:46 AM   #2
Images: 55
There is a product sold by the eastwood company (eastwoodcompany.com) that is pretty close. It is sold as an engine detail paint. I think is is cast iron grey or similar. Check out their site.
Tripp
Tripp is offline   Reply With Quote
Old 07-01-2003, 05:36 PM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Post dealer
your airstream dealer should have it.
it is an exact match. about $22.00 a can.
did my '92 this last spring, cannot tell the differance.
john
Old 07-01-2003, 05:40 PM   #4
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Re: dealer
john
$22 a CAN???? would that be for a gallon can??? OMG! Sticker Shock!!!
Ok... whew... a little more calm now...
John, how about you just send me what's left in yours?
Roger
Old 07-01-2003, 06:30 PM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
marbles
roger,
all you would get is the marble in the bottom of the can.
actually, it is not that bad of a deal. i have paint spraying equipment, binks guns etc.
however, by the time i took the centari number out of my owners manual and got reducer, hardener, prep solvent i would be way over $22.00!! by a factor of two!
so, for a rattle can that sounds expensive. but, given the fact i only need to do it every ten years it ain't bad.
i also got some plasticote in a can. same price, it will be interesting to see how that works.
john
Old 07-01-2003, 07:45 PM   #6
I believe you will find at WalMart..... Dupli-Color stock # T177W Gunmetal (rattle can) a match at about $3.00 per can. Match for my 1988.
George Jr.
George Jr. is offline   Reply With Quote
Old 07-01-2003, 08:09 PM   #7
85MH325's Avatar
Tipton , Iowa
Images: 37
Re: marbles
roger,
john
John...
Whew... I thought I was going to have a stroke there for a minute... I feel much better now... That's a LOT of money for a rattle can.
Thanks for the alternative, George! I bought some that works, but doesn't quite match. I'll see if I can find the #T177W.
Roger
Old 07-01-2003, 08:21 PM   #8
2003 19' Bambi
Images: 21
Thank God for Walmart
3 dollars is worth the try!
Old 07-25-2003, 04:32 AM   #9
1994 30' Excella
New Smyrna Beach , Florida
Frame paint
We have a 2001 Bambi and the front frame paint needed freshing up. I went to Walmart and got two cans of the spray on truck bed liner paint. It is gray/black. It went on easy and has a texture to it. It has been on there for about a year and still looks new. I think it is due to the tuffness of the bedliner paint. Might want to try it. We are very satisfied with the results. In fact, I sprayed the inside of the rear bumper compartment where a little surface rust was seen. Provides a tuff coating and does not chip off easily.
Bob Caldwell
rcaldwel is offline   Reply With Quote
Old 06-14-2004, 09:39 PM   #10
2003 19' Bambi
Images: 21
update on paint
I tried the walmart paint on top of a POR 15 application and its very close. I actually like it better because it has metal flek in the paint. I also coated the propane bottle base plate with duraback bed liner and it is bullet proof. I will post a photo later.
"No good dent goes unpunished."
Old 06-15-2004, 12:14 AM   #11
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
I just did my banana wrap and A frame with a Rustoleum Black Metal Flake that was a little darker, but a very close match....about $3.50 a rattle can.
The exact match is available at the local dealer for $22 a can...uhhhh...NOPE....not gonna do it....wouldn't be prudent.....
dscluchfc is offline   Reply With Quote
Old 06-15-2004, 07:15 AM   #12
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
I'm going to have our frame sandblasted due to all the rust - one of the options we were offered by the guy I talked to was powdercoating to protect it in the future. Any reason why this wouldn't be a good idea on the tongue area? I figure a medium gray or black powdercoated tongue would be practically bulletproof against dings and scratches, and who doesn't like bulletproof?
bredlo is offline   Reply With Quote
Old 06-15-2004, 11:40 AM   #13
upallnight's Avatar
Question
Just curious? did he give you a price quote and are we talking the whole frame?
Leonard
LotalaborAZ
upallnight is offline   Reply With Quote
Old 06-15-2004, 11:52 AM   #14
bredlo's Avatar
1954 22' Safari
He wouldn't talk price without seeing it. I said, "It's a typical ladder style frame, 19 feet long with an indeterminate amount of rust. How about a ballpark?" Nope.
So, it could be so expensive to coat and bake an enamel onto something that size that it's not worth it. But after watching them powdercoat a chopper frame last night on American Chopper, I'm even more convinced that this is the way to near-permanently protect any steel surface from corrosion.
Now, who knows? Once I get a good look at my frame, it might be eaten through to the point of no return, but that's another story.
Dark grey bottom paint. apple 1 Clearcoat, Exterior Paint & Trim 5 08-07-2009 11:23 AM
Exterior paint peeling! Astrodokk Airstream Motorhome Forums 2 08-10-2003 08:18 PM
Eternabond Paint to match Crsoley Kid Airstream Motorhome Forums 0 08-05-2003 06:15 PM
Paint Repair Primer Howard Lefkowitz Clearcoat, Exterior Paint & Trim 2 08-25-2002 11:56 AM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 05:39 PM
