Old 07-25-2010, 10:51 PM   #1
2001 19' Bambi
salt lake city , Utah
tires for 2001 airstream 19 bambi
I recently had a flat tire on my bambi and had a hard time getting the tire off to get it fixed. then I had a harder time getting the fixed tire in the trailer when it was full of air. getting the tire between the axle and the wheel well was a struggle as there was very little space between. I emailed airstream of this problem because I thought that the origanial onwer had put oversize tires on ,but found out they were the proper tires for the trailer. anyone have any sugessions as how to make this an easier fix?
rpchristen is offline   Reply With Quote
Old 07-26-2010, 05:20 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Do not inflate the tire until it is on the trailer.
I went with 225/75-16 tires on my 19CCD and the only way they would clear the hub was to put them, then inflate them. Deflate before you remove them also.
A bit of a PIA, but it worked and the tires fit the wheel well nicely when on.
Old 07-26-2010, 08:43 AM   #3
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Could you possible have a bad axle,allowing the hub to stay too far up in the fender well? That`s what I encounter dealing with these old trailers.Dave
easyride is offline   Reply With Quote
Old 12-31-2010, 11:53 AM   #4
2001 19' Bambi
Ashland , Oregon
The tires on our 2001 Bambi are original. The treads are still pretty good but I am wondering if the rubber deteriorates regardless of how much use they get. My DH thinks everything is just fine but I like extra reassurance.
Should we get new ones now or just keep an eye on the treads?
Kathleenh is offline   Reply With Quote
Old 12-31-2010, 01:52 PM   #5
2005 19' Safari
GLENDALE , AZ
Your tires are going on 11 years old, and they are past due for replacement. If we ever get a pair to survive without a blowout or tread separation, we will change ours every 4-5 years. Southwest desert highways are really hard on tires, as is obvious by all of the alligators on the roads in the summer. However, even in your milder weather, I wouldn't go any longer on your tires, unless your Airstream is permanently parked. For more information (and opinions), search "TIRES" on this site.
Old 03-12-2011, 11:30 AM   #6
2001 19' Bambi
Ashland , Oregon
Phoenix, thanks!
Old 03-12-2011, 11:43 AM   #7
tpi
Trabuco Canyon , California
Get new ones. Frequently tire failures cause lots of collateral damage such as bent sheet metal, impinging on the tanks and plumbing, etc. which can be plenty expensive to fix.
tpi is offline   Reply With Quote
Old 03-14-2011, 11:43 AM   #8
2001 19' Bambi
Ashland , Oregon
Tpi, I am very anxious about this. People look at the tires say they 'seem fine' which my DH takes to mean we needn't bother right now. I'd rather do it now than wait for a blowout. I'll have to work on him some more. We did just replace all four tires on our tow vehicle which cost a bundle and he isn't in the mood to talk about replacing the A/S tires but I think we need to do that.
Thanks for the enlightening comments, all.
16' 2001 Bambi needs a little TLC JFlach Member Introductions 3 08-02-2011 02:39 PM
2001 airstream bambi eBay Watch Airstreams on eBay 0 07-11-2010 11:10 PM
2001 Bambi kevin242 Airstreams on eBay 0 01-12-2010 07:29 PM
2001 Airstream Bambi 16ft 70th Anniversary No Reserve!! eBay Watch Airstreams on eBay 1 05-11-2009 01:12 PM
Flat Tires on 2001 Bambi pfishman Tires 2 01-07-2005 12:31 PM
