Old 05-12-2005, 07:45 PM   #1
1980 20' Caravelle
Coeur d alene , Idaho
Size of Front Window 19 safari Bambi?
Is the width of the front window smaller on the newer 19 foot Bambi , campared to the 2000-1 model? I can tell the back window is alot smaller but what about the front? Any good reason for AS to put in smaller windows? Thanks, Don
glacierrunne is offline   Reply With Quote
Old 05-12-2005, 07:57 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I don't believe the fronts are different. However I did see what I thought was a 99 or 00 19' Bambi with a wider rear window than the model of the last 2 or 3 years. I took a look since I knew the shower was in the same area and I could not see in the far left of the bigger rear window. I figured it was a bigger window, but only 1/2 to 3/4 actually was window space you could see through because of the shower wall being in the way.....so then I figured the window was made smaller in back because there was little point to a larger back window when only part of it could be actually used?
Anyway, that's my story and I'm stickn' with it!
Old 05-12-2005, 10:06 PM   #3
1980 20' Caravelle
Silvertwinkie, I see your point about the rear window. On the tread "Bikes and Bambi" shows a picture of the larger 2000 window, it looks better with a window centered, but point taken you can't see out the entire window. Thanks, Don
Old 05-13-2005, 07:07 AM   #4
Aluminut
2004 25' Safari
. , Illinois
I agree....it does look better...and when I first saw it, of course you know I ran right up to it thinking, what a great idea......until reality set in and I said, hey that's where the shower wall is....
1961 Bambi '16 (Serial #16TDSS1728) Andy R 1961 - 1963 Bambi 28 02-27-2012 10:57 AM
Front Window Rockguard themartaman Windows & Screens 3 07-14-2002 11:01 AM
outside window covers 83Excella Rock Guards, Segment & Window Protectors 2 06-30-2002 06:24 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
