Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Bambi > 1999 - 2004 Bambi
Old 09-10-2003, 06:53 AM   #1
dtbw
dtbw's Avatar
Profile:  1999 34' Limited
2002 19' Bambi
Allen , Texas
Sheets that FIT!!
Just wanted to pass along a tip for those that are still struggling with ill fitting sheets on the Bambi. www.sheetsusa.com is a US company that manufactures customs sheets for RVs (and Airstreams in particular) in Nebraska. They have a really neat design. The top and bottom sheets are attached at the foot. The bottom sheet, at the head, has a pocket that ships over the mattress, then the sheet set is pulled to the foot, tucked in and locked in place with velcro in such a way as to form another pocket. No elastic used. Once the bottom is locked in place, the top sheet is then pulled back to the head and there is NO way that either sheet can be pulled loose. The design incorporates the rounded corners of our beds. The price is $37.10 and that includes 2 pillow cases. The quality is top notch. Highly recommend.
Also, they have custom sheets for MANY other A/Ss so check out the website. If you don't find your exact model, give them a call and talk to Deb as they may have patterns already, just not showing on the website (that was the case with the Bambi). Really nice people to work with.
david & bret
'02 Bambi LS
'99 34' Limited
President Heart of Texas Camping Unit
WBCCI # 7548
dtbw is offline   Reply With Quote
Old 09-10-2003, 07:04 AM   #2
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
I can't get the link to work. Google can't find them under that name, either.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 09-10-2003, 07:14 AM   #3
yargseth
yargseth's Avatar
Profile:
Images: 12
John
Go to www.sheetsusa.com They fit great!
Gary
yargseth is offline   Reply With Quote
Old 09-10-2003, 07:21 AM   #4
dtbw
dtbw's Avatar
2002 19' Bambi
Allen , Texas
Sorry, a typo
Thanks for catching my typo. As has already been reported, it is www.sheetsusa.com
david & bret
'02 Bambi LS
'99 34' Limited
WBCCI # 7548
Old 09-10-2003, 07:58 AM   #5
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Great! thanks for posting. Have to order a couple sets. Should fit our Carvanner.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 09-10-2003, 08:41 AM   #6
dtbw
dtbw's Avatar
2002 19' Bambi
Allen , Texas
Be sure to check...
Before ordering, carefully measure your mattress size. These sheet sets are tailored to an exact fit. Also, the Bambi set has rounded corners at the left head and right foot areas. I originally ordered the set for the International CCD as that was the closest size they listed at the time. They did fit width/depth wise but were a bit too long. I was going to just modify them, but then yargseth called them on the same issue and they found where they had made a set exactly for a 1999 19' previously, so they asked us to both to return our incorrect sets and they would replace them with the exact fitting set. If your mattress does not measure exactly to the dimensions shown on the website, I would contact them before ordering to see if they have a better fit.
david & bret
'02 Bambi LS
'99 34' Limited
WBCCI # 7548
Old 09-10-2003, 09:08 AM   #7
59toaster
59toaster's Avatar
Atlanta , Georgia
Images: 22
Re: Be sure to check...
Ok will get some measurments. Ours is street side for the curve.
I think the internet is broke....haven't been able to visit the site yet....Seeing a lot of sites like that today.
1959 22' Caravanner
Atlanta, GA
Old 09-10-2003, 09:21 AM   #8
spinolio
spinolio's Avatar
Profile:
great sheets indeed!
I have a set of these for my 310 Motorhome and they are fabulous. I recommend sending an exact diagram with all measurements when ordering. Sheetsusa originally made ours to the wrong dimensions, but re-made them immediately and without charge when their error was pointed out, Outstanding customer service!
spinolio is offline   Reply With Quote
Old 09-10-2003, 09:29 AM   #9
rfield54
rfield54's Avatar
Profile:  1980 28' International
1989 29' Excella
2002 19' Bambi
Avon , Colorado
Images: 103
The only issue I have with this company is they only use Percale which is 50/50 (cotton/poly). The reasoning being that 100% cotton shrinks, and that could be a problem wiith the (I assume) tight fitting design. For sheets, I'm a 100% cotton fan myself, so I'm going to take a set of cotton FLANNEL sheets and alter the bottom sheet a bit. Possibly sew in a cord along the edge of the fitted sheet so I can sinch the sheet around the underside of the mattress. The alteration shouldn't take long. I'll probably replace the elastic with the cord.
rfield54 is offline   Reply With Quote
custom sheets yargseth 1999 - 2004 Bambi 3 09-11-2003 05:05 PM
Dumb Question regarding the bed & sheets kamadeca 2003 Safari 8 06-23-2003 02:24 PM
Reese dual cam sway - fit??? Craig Hitches 4 06-18-2003 04:50 AM
Fitted sheets Pahaska Upholstery, Blinds, Walls & Interior Finishes 11 11-22-2002 11:32 PM
Will this couch fit my trailer?? JohnGalt48 General Interior Topics 4 08-07-2002 06:38 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
