Old 03-04-2019, 05:32 PM   #1
Mrsretail6
2019 16' Sport
Springdale , Arkansas
Quick connect back up camera.
Just a quick question! Are any of you familiar with this quick connect back up camera or have used this system. Any knowledge would be appreciated. https://www.rearviewsafety.com/rear-...ct-system.html
mrsretail6 is offline   Reply With Quote
Old 03-04-2019, 05:42 PM   #2
2007 22' International CCD
I have this one, has a different monitor, but they both use the same rear-view camera.
https://www.rearviewsafety.com/safet...70616-213.html
Seems to work decent, and several others have used them that I know of. They work real nice on the vintage motorhomes.
The rough bit with mine is you need to drill holes to mount the side cameras...good thing I'm not afraid to punch small holes in shiny aluminum trailers. (oooh, I'm gonna get flamed for that one!)
The one thing I didn't like is that the trailer to tow vehicle connectors SCREW together, and in the event of a busted hitch or other trailer disconnect, the cable is going to get broken if its a full breakaway. Trivial issue in the larger sense of an event like this, but it's the only thing I can come up with that's even a tiny bit wrong with the system...
Old 03-04-2019, 05:58 PM   #3
Mrsretail6
2019 16' Sport
Thanks for the input rmkrum!
Quick connect extra propane fitting Rich of SCal LP Gas, Piping, Tanks & Regulators 21 08-21-2016 12:10 PM
LP Quick Connect for Gas Grill Mod-Streamer LP Gas, Piping, Tanks & Regulators 13 06-10-2015 04:20 PM
Propane quick-connect callmedave LP Gas, Piping, Tanks & Regulators 31 03-10-2015 11:53 AM
Quick Connect - water inlet? Kevin245 Fresh Water Systems 10 05-13-2009 04:26 PM
A new kind of quick connect 12V outlet Westfalia Electrical - Systems, Generators, Batteries & Solar 3 09-04-2005 06:26 PM
