Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Bambi and Bambi II > 1997 - 2004 Bambi
Old 04-21-2004, 08:07 AM   #1
Bellevue , Washington
Question Looking at 2004 19' Bambi Safari
Hey Folks,
We are so grateful for the great information on this forum! We are negotiating with a dealer on a 2004 19 Foot Bambi Safari... looking at trading in our current trailer (not an Airstream but book value is $3000). Dealer started with a price of about $28,000 and is down to $25000 including the trade in. The Bambi we are looking at was in the recent "RV Show" and seems to be in good condition: has the spare tire, the Fantastic fan, two batteries. We have some questions for any experts out there: how is this purchase price? we are considering solar: any suggestions on that? we are considering the black tank flush: what do these cost, who makes them and is this something to get installed now? A stupid question: the dealer provided a manufacturer's "build sheet" which supposedly lists the items on this unit. It lists two stabilizer jacks: is this true (we need to take a look on our next inspection at the dealership). We have seen a lot of discussion in the forum about the "date" that a unit was manufactured: should we ask about this? Is there a "problem period"? Finally, is there any advantage to just ordering a new unit from the factory, in terms of price and options? We are not looking for luxury but practicality: we are "dry campers" who have traveled extensively in our current trailer all over the west and Canada. Oh, what is the price of those power front jacks and are they worth it? Thanks for the help.
jschelle is offline   Reply With Quote
Old 04-21-2004, 09:08 AM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Hi. Congrats on the upgrade to a Bambi! Most of the 2004 have been fine. There have been a few exceptions, but you can read about the 2004 quality here:
http://www.airforums.com/forum...2485#post92485
I would say that a unit built on or after 9/2004 should be mostly problem free or at least that was my take from the thread. We upgraded to a 25' Safari C that was built on 12/2004 (we traded the 2003 Bambi) and it so far has had little that would make me raise an real concern.
I would not and did not go solar as it doesn't really provide the power needed. It will give you a boost, but I believe that the current package offered by Airstream was discontinued. Based on cost when it was avail, I'd suggest getting a Honda inverter generator based on your power needs. Folks that have them, love them and they provide many times over the power needed....and they are VERY quite, but no one is giving them away!
The Bambi unit does have 2 stabilizer jacks located aft. I thought that with the LS upgrade which would include the fantasitc fan and black tank flush (although some builds did get some parts of the LS upgrade, but not the full LS upgrade) had 4 stabilizer jacks. I will tell you first hand that having had an '03 Bambi, 4 jacks are far better than just the two in the rear. I would strongly suggest looking into getting the other two installed in the front if it does not already have them, even if it was at an additional cost. Also make sure whomever installs them, knows where they go and what the heck they are doing. I was going to have the front set installed, but then we decided to trade up to the 25' unit. I had some basic RV stabilizer jacks I used, but it was kind of a pain to have to schlep them around. Having them perm attached is by far the best setup that I have found.
I was indifferent to the black tank flush until we got one when we upgraded to the 2004 Safari C as part of the LS package. I love it. Makes life very easy when flushing out the tank. It can be added later, but it is a PITA to do so. I think it required dropping the underbelly skin, dropping the tank, and cutting into the outer sheetmetal to add the exterior access. I'd be VERY careful with this one if it does not have it from the factory--particularly when having to cut in to the outer skins. One thing to note, is that some dump stations do NOT have a threaded hose to connect. I am in the process of fabricating some rubber neck that would work in those situations. To put it in perspective, of the 8-10 trips we took, we found that 50% or more of the campgrounds did NOT have threaded conenctors on the hoses.
We boondock too, but we also stay at some places with 30 amp hookups. To that end, if you too stay at places that have electricity, I would suggest upgrading the air conditioner to a 13.5k unit. I found in direct sunlight, the 11k standard unit did struggle a bit to keep up. I feel that for folks going larger than 22' the 15k units should be considered (I did).
The power jack is very nice and an easy install and a nice option...after you've cranked it a few times in one day, you'll know what I'm talking about!
The price that you mention, based on knowing there was a price increase seems fair. The iron is hot right now so dealing is a bit harder than it has been, but the 2005 models should start coming out in a few weeks, so the dealer might be trying to blow out the remaining 2004s. There is however another price increase slated for the 2005 model year from what I understand, so if you go the 2005 route, expect to pay closer to $30k depending on options and the dealers willingness to come down to the average 20% off list.
Hope this helps. PM me if you have an more questions, I'd be happy to share additional comments.
Eric
Old 04-21-2004, 08:48 PM   #3
WayWard Wind's Avatar
2004 25' Safari
Eric---If you go to camperschoice.com--look up P376 it's called "water thief' & is just for those hoses that have no end connections. If you get two --one for fresh water & one for black water, try to keep them seperate , it helps in the long run. Also we have a 02 Bambi & it doesn't have the Black Water Flush. We were going to get it installed at the factory, but found that the King Flush thing works really well when flushing the black water tank. If I remember correctly they wanted somewhere around $450 to install. I just can not believe that they do not make the Flush a standard part of a unit. It's something you have to do everytime the unit is used & to drag a hose thru the unit is .I'd ditto the rest that you said regarding the 19'.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 04-21-2004, 09:27 PM   #4
Aluminut
2004 25' Safari
. , Illinois
Hey thanks a bunch...that is EXACTLY what I was going to build!
Quality of new AS: 2004 22' SAFARI lee 2000 - 2004 Safari 7 01-02-2005 07:13 AM
Proud Owner of Safari 2004 AirHog 2000 - 2004 Safari 10 04-05-2004 09:19 AM
2004 Safari 28' W interior photos idahosafari 2000 - 2004 Safari 8 11-16-2003 01:52 AM
2004 Safari 28' W idahosafari 2000 - 2004 Safari 2 10-30-2003 10:35 PM
CCD International 19 Bambi vs Safari Bambi vajeep 1997 - 2004 Bambi 8 10-02-2003 04:16 PM
