Old 07-20-2003, 03:20 PM   #1
Question lock of screen door on 16 foot-Bambi
I have a 16 foot, 2000, Bambi with a screen door that doesn't have a lock on it. Sometimes when it is really
hot outside, we, my husband and I leave the door open at night. But I am really nervous about leaving just the unlockable screen door as the only protection. Is there a way to lock the screen door? Does one just buy a lock, if so what kind. Or do I need to get a whole new door? Thanks for any help. GloriaJoan
gloriajoan is offline   Reply With Quote
Old 07-20-2003, 03:51 PM   #2
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Locks
Some one could reach into the plastic slide, so it would almost have to be a key lock like the keyed deadbolts that are used next to a glass window on a house.
There isn't much structure there, but with a little poking around the hardware store or a lock shop I'll bet you could come up with a solution. You will probably have to rivet or screw a piece of aluminum to the door frame to get enough area to mount the lock.
One thing I can think of off the top of my head is a lock for a sliding window sash. I have seen these window locks with keys. One of these locks could be mounted vertically on the door and the lock keeper mounted on the frame. You could probably use aluminum angle to make the necessary mounts.
John W. Irwin
WBCCI #9632
Old 07-20-2003, 04:50 PM   #3
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
a screen is not protection...
A screen door is not going to keep someone out. It is designed to keep bugs out, not people. Leaving the screen door open either locked or unlocked is not the same as a solid door.
Any screen can be quickly and quietly slit with a knife or razor blade and the locking device easily defeated.
If you want to be secure, you can leave your windows open as they're difficult to get through, but use your door and it's locks.
Roger
Old 07-20-2003, 07:15 PM   #4
Pahaska's Avatar
Hays County , Texas
I disagree
I fully appreciate gloriajoan's desire to have some kind of lock on the screen door. While it certainly will not keep a determined individual out, a screen door with a key lock will just as certainly delay them for a fair amount of time and cause a whole lot of commotion, rousing the occupants and allowing some response. Presumably, she is not out in the wilderness somewhere when all this is happening, but more likely in a campground with reasonable proximity to other RVs.
Her screen door should be exactly like mine; with the guards on the door, cutting my screen will not let an person in if the door can not be opened. That is why I advised a keyed lock, so that someone reaching in can not unlock it.
I have considered some sort of extra lock on my screen door, not for security, but because I travel with a cat and I don't want some well intentioned friend to open the screen door unexpectedly.
John W. Irwin
WBCCI #9632
Old 07-20-2003, 07:18 PM   #5
Pahaska's Avatar
Hays County , Texas
By the way
It would be a lot easier for someone to ge in through my escape window than through a locked screen door.
John W. Irwin
WBCCI #9632
Old 07-20-2003, 08:24 PM   #6
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
GloriaJoan
One option is to have your dealer, or there is a guy who does this at international rallies, install a deadbolt on your entrance dorr. With the entrance door open and deadbolt extended you in effect have a locked screen door.
We did this to out 77 traielr and it was nice to have when you have 2 great danes who want to push the door open from inside!
If that is to agressive (holes intrailer, etc.) then you can purchase a slide bolt like this either form Airstream or at Home Depot if you dont mind a brass one.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 10-16-2006, 08:01 AM   #7
New Smyrna Beach , Florida
Locks/Alarms
I just installed a small *silver* alarm on the screen door of my 19ft Bambi. A $6 purchase at the hardware store and it's great when I'm inside for a short nap or quick shower.
Adhere one piece to the screen door frame and the other to the door jamb. When the door is opened and the two pieces break contact, the alarm goes off.
Safety first, though. When I'm in for the night, I always lock the main door.
knicastro is offline   Reply With Quote
Old 10-16-2006, 09:40 AM   #8
ScottW's Avatar
Hernando , Mississippi
A lock on the screen will only slow down an intruder. How you deal with the perp once he/she is inside is up to you. Both of us have a license to carry - and do. But then, I'm from the south. The choice is yours.
Scott
ScottW is offline   Reply With Quote
Old 10-16-2006, 01:44 PM   #9
On the road , again...
Note to self...always knock before entering SCOTTW trailer.
rebfa is offline   Reply With Quote
Old 10-16-2006, 03:26 PM   #10
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Hey, might as well add my trailer to that list.
Old 10-16-2006, 03:30 PM   #11
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Scott
Scott, be very carfull. If your aim is off at all, you are going to have a real problem with your campers skin........
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 52 05-08-2018 01:31 PM
1961 Bambi '16 (Serial #16TDSS1728) Andy R 1961 - 1963 Bambi 28 02-27-2012 10:57 AM
16' Bambi bed conversion Wish General Interior Topics 0 12-08-2003 04:27 PM
Newbie Pondering Bambi 16 or 22? Joe Our Community 10 09-20-2003 08:37 AM
Bambi or 16' CCD Shep Our Community 27 07-18-2003 08:51 PM
