Originally Posted by bensonortho
A carpet cleaner claims the stains are coming from behind the carpet
I've seen some gray stains on newer units coming through the white wall carpet and they all appeared to be along an interior rivet line. My assumption is this is caused by very small metal shavings developing along the rivet lines. Anyone else have any ideas? If this is the case the carpet cleaner is probably correct that you will not get the stain out while the carpet is on the wall. Joe
