Old 09-08-2003, 06:04 AM   #15
dtbw's Avatar
1999 34' Limited
2002 19' Bambi
Allen , Texas
Make A/S send you one
Nancy,
That should have been installed by A/S, but if the retrofit hangs lower than original factory, then A/Ss standard bracket would not extend low enough. Still they should have had a custom bracket made. Regardless, I would have A/S send me one of the brackets as it would be a good pattern for a sheet metal shop to use in fabricating a bracket that would extend down properly. While the weight of the plumbing is small, it is the leverage situation that concerns me. Without the support at the center, there is a good potential for motion and over time that could lead to fatigue at gray or black tank exits (or both). I will be getting our Bambi out of storage later next week and I will do some measuring so that we can compare clearances.
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
Past President Heart of Texas Camping Unit
WBCCI # 7548
dtbw is offline   Reply With Quote
Old 09-10-2003, 08:00 PM   #16
B25guy's Avatar
2003 25' Safari
Yakima , Washington
Images: 20
sewer valve bracket
Here's a picture of my alum angle bracket...nothing fancy, just functional. I attached the forward end of the angle with a #12 sheet metal screw (hex head) to the nearest outrigger just forward of the valve. I then lifted the valve assy slightly to remove the slack then drilled and riveted the two together. Now there's no wiggle in the valve and should hold up nicely as the valve handles are tugged on through the years.
BTW, the alum angle was a scrap leftover when I put mud/rocks guards behind the rear axle. I noticed lots of mud and dirt around the valves and rock chips in the underside paint.
Hope this helps!
B25guy is offline   Reply With Quote
That pesky grey water that bypases the holding tank Van All Argosy Trailers 15 08-13-2004 07:52 AM
Pulled the plug out of the Holding Tank? ssolid Fresh Water Systems 0 03-24-2004 11:13 AM
holding tank question.. Morning Dew Waste Systems, Tanks & Totes 1 03-19-2004 03:44 PM
Holding tank Question GOTPIKE All Argosy Trailers 4 08-20-2003 09:35 AM
General plumbing question eracism Fresh Water Systems 2 01-14-2003 06:41 AM
