Old 07-14-2006, 07:40 AM   #1
Send a message via Yahoo to dhe9
hisssssss
my 2003 bambi battery is now hissing when plugged into the 110. i assume the battery is going bad and understand i should replace both. several questions here:
1. can i assume that one battery is no good as it seems to be boiling and what is causing the hiss while plugged into 110?
2. can i remove the bad battery and just run off the good one? i have a trip coming up to the east coast and won't really need but one battery as i will be only using the water pump in the morning while traveling. would any damage occure from traveling with just one battery hooked up?
3. anything happen if i have no batteries in the trailer but have it hooked up to 110?
thanks,
david
socal
'03 19' bambi
2011 CTD DIESEL
SEMPER FI
RETIRED USMC
dhe9 is offline   Reply With Quote
Old 07-14-2006, 08:46 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
David,
No problem to run on one 12 V battery instead of 2. You will just have half of the available amp-hours that you had with both. Don't know what your budget is for replacements but I would look at the Lifeline AGM batteries. No liquid, hissing or boiling.
I would also have the converter's charging circuit output checked to be sure that the problem did not originate there and was just a bad battery. 3 years is normal for a lead-acid type battery anyway.
Old 07-14-2006, 10:17 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
thanks,
david
socal
Yes, the electronics in the charger could suffer if there is no battery in the circuit.
