Old 07-26-2016, 09:02 AM   #1
austin , Texas
Generator recommendation?
I have a 2000 19' Bambi. My Yamaha 3000 generator just bit the dust. Carb replacement will cost $1,000 + before taxes.
New Honda 2000 should cost roughly the same or less.
Can I run my A/C on ONE Honda 2000? it is HOT in Austin, Texas & I'm looking for a solution.
Any advice is welcome!
Thanks.
SoonerStream is offline   Reply With Quote
Old 07-26-2016, 09:27 AM   #2
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
The answer depends upon the size and power demand of your air conditioner. I'm guessing the answer is "probably not" unless your AC is in the 8,000 or less BTU range.
kscherzi is offline   Reply With Quote
Old 07-26-2016, 09:29 AM   #3
W4NT3D's Avatar
2016 27' Flying Cloud
Saint Robert , Missouri
I don't think so, look at what your power draw is for the AC, then see what one Honda 2000 generator pushes. You may need to parallel two of them or get one bigger generator.
W4NT3D is offline   Reply With Quote
Old 07-26-2016, 09:35 AM   #4
Al Boondy's Avatar
1973 31' Excella 500
Vicksburg , Mississippi
Thanks.
My advice is to get a second quote on replacing carb. $900 for labor seems a little steep imo.
Al Boondy is offline   Reply With Quote
Old 07-26-2016, 11:14 AM   #5
2015 28' Flying Cloud
Newtown , Pennsylvania
x2
Bruce
50 amp, Awning package
2015 Ram 2500 6.7 TD, Blue Ox 1000 lb.
4 Lifeline AGM, Trimetric 2020
PD9160 converter, Prosine 1800 inverter
2x eu2000i Propane
AstroBruce is offline   Reply With Quote
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Solar or generator or and generator? badkat Full-Timing 15 11-17-2014 09:59 PM
Moab-recommendation! WolfSong Our Community 33 03-05-2004 09:34 AM
Recommendation on weight distribution hitch davidlaxson Hitches, Couplers & Balls 30 08-31-2003 09:38 PM
Recommendation for skin repair in Northeast? rluhr Commercial Listings 5 08-28-2003 09:14 AM
