Old 04-24-2017, 03:10 PM   #1
2003 19' Bambi
Beaver , Pennsylvania
Gas or Electric water heater
I recently inherited a never used 2003 Bambi and am trying to figure out if the water heater runs via electric and gas or just gas. The panel above the bathroom sink doesn't give me much help. Also, since I do not believe the hot water system was ever used, what do I need to do to be safe before turning it on? From my understanding, water has to get into the hot water tank via the water pump? where is that located and how does that work. I've very new to all of this and although I've been reaching the manual, I'm not much of a technical person. Any help would be great. Thanks!
bambiangel is offline   Reply With Quote
Old 04-24-2017, 03:37 PM   #2
Mount Dora , Florida
Either fill the fresh water tank and turn on the pump, or connect a hose to the city water inlet. Then make sure your water heater is not bypassed for winter storage. Run the hot water taps at every sink, shower, outside shower, etc. until it stops sputtering air and you get a steady stream of water.
That fills your water heater, and it's now safe to turn on the heat. Turn on the electric heater first (connected to shore power) and let it heat for 10 minutes. Run the hot water and see if it's warm. If so, turn off the electric heat and turn on the propane switch. Go outside to the water heater vent and listen for the burner operating. If it's burning, you're good.
Be careful if it gets to full temp, I think mine is set to 140F. Probably not enough to injure, but it is plenty HOT!
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 06-20-2019, 09:24 AM   #3
2000 19' Bambi
MIDDLETOWN , RI
was electric hot water, in addition to propane heated, a "standard" feature?
GaryRI is offline   Reply With Quote
Old 06-20-2019, 09:35 AM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
The other way around.
Propane allows you to camp off the electri grid. Many county, state and federal campgrounds have primitive camping. So, with water in your white (supply) tank and the gra uh and black tanks to store waste water, add propane for cooking and heating water, and batteries for 12 volt lights, you can stay several days without services.
Foiled Again is online now   Reply With Quote
Old 06-20-2019, 02:06 PM   #5
Long Island , New York
Did your 2-year old questions get fully answered?
Happy Trails,
Peter
Atwood LP/Electric Water Heater Problems (Electric Has Failed) gquake Water Heaters, Filters & Pumps 10 06-29-2014 03:02 PM
Am I Stupid? Water heater gas and ELECTRIC THEPILL Off Topic Forum 25 10-21-2011 05:08 PM
Water heater efficiency GAS vs ELECTRIC in Landyacht class A daveshrader Water Heaters, Filters & Pumps 7 02-18-2010 04:38 PM
Switch for Atwood Gas/Electric Water Heater tr674 Water Heaters, Filters & Pumps 8 07-20-2008 10:33 PM
Gas and Electric water heater and furnace Jim Casavant General Motorhome Topics 4 08-07-2007 07:28 PM
