Old 04-03-2004, 09:11 AM   #1
luckydc's Avatar
Richmond , Virginia
First time water fill-up....
Need to make sure I know waht I am doing as I contemplate checking the water lines on the new Bambi. I see lots of by-pass valves and want to make I get them all!!
I closed the low point valves in the rear and closed the hot water heater by-pass under the bed.
I am looking for the low point by-pass in the front. I see one, and think I see the other. I guess my question is, is there a valve into or out of the water pump? I don't think so....
Okay, with the by-pass valves closed, connect to city water. Open hot water faucets one at a time until steady stream. Than open cold water faucets until steady stream. Bingo?!
What did I miss?
Thanks!
Paul
WBCCI #2468
2006 Ford F-150 Lariart 4X4
2004 19' Bambi Safari LS
luckydc is offline   Reply With Quote
Old 04-03-2004, 01:16 PM   #2
RichardT's Avatar
Check water heater drain and pressure valve too! also if it has a bypass for winterising put that in correct position also.
RichardT is offline   Reply With Quote
Old 04-03-2004, 03:35 PM   #3
luckydc's Avatar
Richmond , Virginia
Pressure valve? Do you mean the in-line pressure valve? What am I checking it for?
What bypass for winterising? Hot water heater? Got that.
Water heater drain? Will have to look more for that.
Thanks, Rcihard.
Paul
WBCCI #2468
Old 04-05-2004, 05:48 PM   #4
RichardT's Avatar
I mean the pressure relief valve on the water heater, make sure it is closed.
Argosy water fill problem mcneon Argosy Motorhomes 1 10-09-2003 05:30 AM
water system mystery garymacf Plumbing - Systems & Fixtures 4 06-21-2003 11:50 AM
Electric hot water on all the time? Kistler Our Community 3 05-13-2003 03:10 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
Water leaks 53flyingcloud Our Community 2 11-28-2002 01:07 PM
