Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Bambi and Bambi II > 1997 - 2004 Bambi
Old 05-05-2003, 08:28 PM   #1
WayWard Wind's Avatar
2004 25' Safari
Electrial surge charge controller
I'm interested if anyone has tried one of these surge controllers & if so how did you find they worked ? I'm considering looking into cutting my entrance 30 amp connection below the closet area & bringing the wire up into the closet area & hard wiring it to a surge controller. This would allow me to monitor the electrial system, should it default, from inside the trailer & would lessen the chances of the controller getting legs & walking off. I have previously been advised that one should chain lock the controller if used outside. Would appreciate any feed back if you have or are using a surge controller, Best
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Can I Trickle Charge into the 12V Wall Jack? westeagle Electrical - Systems, Generators, Batteries & Solar 5 01-21-2004 03:19 PM
Hensley Brake Controller $427 New markjoandall Brakes & Brake Controllers 2 11-19-2003 06:47 AM
Brake Controller Hook-Up Dimick Brakes & Brake Controllers 6 03-09-2003 01:44 PM
Magnetic Brake Controller MattyBoy Brakes & Brake Controllers 3 01-04-2003 01:29 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
