Old 04-01-2004, 03:45 PM   #1
luckydc's Avatar
Richmond , Virginia
Disconnect Electric Hitch Jack??
First dumb question - how do I kill the power to the electric hitch jack? Kill switch inside trailer is on store, but light on the jack head and hitch jack still work......
Paul
WBCCI #2468
2006 Ford F-150 Lariart 4X4
2004 19' Bambi Safari LS
luckydc is offline   Reply With Quote
Old 04-01-2004, 03:59 PM   #2
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
DC to Hitch Jack
Paul,
Your Bambi should have an in-line fuse holder on the cable running to your power hitch. If you remove the fuse at your campsite, this should discourage anyone from "monkeying" with your hitch.
rseagle is offline   Reply With Quote
Old 04-01-2004, 04:03 PM   #3
luckydc's Avatar
Richmond , Virginia
Thanks, Bob. I had a feeling that was the best way to do it. I wonder why AS doesn't put it on the kill switch? Oh well...
Paul
WBCCI #2468
Old 04-01-2004, 04:15 PM   #4
rseagle's Avatar
Images: 33
DC To Hitch
Paul,
Glad to help. I notice that you're right up the road from me. May I ask where you bought your Bambi. We have a dealer (Stafford RV) here in Fredericksburg that sells and services A/S, but I went to Colonial in NJ to get my 22' CCD. They had the largest inventory in the region, so we were able to walk through alot of different models before deciding on an instock model.
Old 04-01-2004, 04:25 PM   #5
luckydc's Avatar
Richmond , Virginia
I went to Colonial, too. Shopped Stafford Dodge by you and Parkview in Delaware, but Colonial gave me the best price. Also, the people I talked to at Stafford and Parkview where not very knowledgeable. David at Colonial worked for my business. I had already decided on the unit and options, so I was able to order it over the phone. It was a long drive up and back, though. Saved about a grand, so it was worth it.
Pretty in Fredericksburg. I was raised in Richmond, which is where my heart still is, but the Rappahannock river ain't so bad either...
Paul
WBCCI #2468
Old 04-01-2004, 05:11 PM   #6
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
So is my trailer weird? When I turn off the univolt under the divan the jack won't work
Kistler
Kistler is offline   Reply With Quote
Old 04-01-2004, 05:26 PM   #7
luckydc's Avatar
Richmond , Virginia
K -
Sounds like you are lucky....
Paul
WBCCI #2468
Old 04-01-2004, 05:29 PM   #8
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Exclamation
Originally Posted by luckydc
K -
Just an FYI: One of our forum members had his jack emulate a pogo stick while towing, with obvious results. It is better to disable for towing, as well as while parked.
Old 04-01-2004, 05:36 PM   #9
I put an inline switch to the jack in my battery box. When I'm towing or set up at the campground, I just flick the switch off. A little quicker / easier than having to pop the fuse out every time.
Deppdog is offline   Reply With Quote
Old 04-01-2004, 05:58 PM   #10
rseagle's Avatar
Images: 33
Paul,
Small world! I grew up in Richmond, as well. I graduated from Manchester HS, on the Southside.
rseagle@earthlink.net
Old 04-01-2004, 06:13 PM   #11
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Smile Likewise mine
Kistler
In fact, the last check I make when leaving the trailer at the storage yard is to hit the jack switch to make sure that I had turned off the batteries,
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 04-01-2004, 06:26 PM   #12
Kistler's Avatar
2002 25' Classic
I agree I like the "arrangement" and do the same. I have a little trouble remembering what I did and what I did not do.
Kistler
Old 04-01-2004, 06:40 PM   #13
luckydc's Avatar
Richmond , Virginia
All right for those fancy Classics......
Paul
WBCCI #2468
Electric Jack Dbraw Jacks, Stabilizers, Lifting and Leveling 17 05-22-2006 05:33 PM
Kill switch for electric jack ? remark83 Jacks, Stabilizers, Lifting and Leveling 9 06-24-2003 10:14 PM
Electric tongue jack not extending ipso_facto Jacks, Stabilizers, Lifting and Leveling 5 03-25-2003 11:58 AM
removing electric jack CHRIS CANNON Our Community 0 09-30-2002 06:51 PM
