Old 08-14-2018, 11:22 AM   #1
Elgin , Texas
BW Tank access?
Does anyone here know how to get access to the BW tank? Thanks!
4seasons is offline   Reply With Quote
Old 08-14-2018, 11:29 AM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
That depends on what Airstream you have and what kind of access you want. For things like flushing out the tank, for example, in most trailers you could just stick a flush wand down the toilet but some have macerator toilets, etc.
Is this to fix a leak? A clog? Retrieve something so precious it's worth the experience?
David
Old 08-14-2018, 11:31 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
What coach do you have?
What is your problem?
Old 08-14-2018, 05:11 PM   #4
Elgin , Texas
Oops!
Sorry...
2001 Bambi 19’
A blowout on the TT tore the plumbing off. The piping broke at the flange coming out of both GW and BW tanks. I can get to grey water tank from underneath but the BW tank is above the plywood and below the commode with no apparent access. Because the break was right at the reducer fitting exiting the tanks I need to be able replace the fittings. In addition to the repair I want to see if I can upgrade the 8 gallon BW tank to the later (03?) 17.3 gallon.
Old 08-14-2018, 05:41 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Sounds like you will have to remove the toilet and it's platform to gain access.
Not intimately familiar with a Bambi. I am sure others here can help.
Especially with going with a larger tank.
Replacing MicroPulse tank sensors and tank access on 22FB SilverHouseDreams 2005 and newer - Bambi all models 2 06-20-2018 10:06 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
1974 Sovereign Gray Tank access tkmore Plumbing - Systems & Fixtures 7 06-14-2008 07:55 AM
Fresh Water Tank Access Badco8 Waste Systems, Tanks & Totes 2 03-25-2007 04:34 AM
Fresh Water Tank Access Badco8 Waste Systems, Tanks & Totes 2 03-24-2007 10:22 PM
