Originally Posted by grizzy I know this has been covered somewhere but I can't seem to find it. Tomorrow morning I'm having high pressure valve stems installed on my 2001 Bambi 19'. I want to make sure Discount tire places the jack in the right location. The book says there is a "Jack" lable behind the rear wheel showing where to place the jack. There is no such lable. Can anyone tell me where the correct position is to place the jack to change a tire on an 01 Bambi?
Thanks |
Check Under the unit behind the tire and you will, or should, find a label and a plate attached to the undercarriage that indicates the spot for the jack to be set. You might also check in your manual for the torque value for the lug nuts and make sure they are not torqued beyond the recommended value.
