Old 09-26-2003, 08:56 AM   #1
yargseth's Avatar
Images: 12
automatic ride suspension
I pull my 19 bambi with a truck that has automatic ride suspension
(air shocks rear). I probably do not even need equalizer bars but found a set of #750 bars. In past trailers always felt rig more stabil with bars. Should I just pull fuse on leveling system and use bars to level? I have not had chance to pull leaving for texas october. Any suggestions appreciated.
Yargseth
yargseth is offline   Reply With Quote
Old 09-26-2003, 10:02 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Yargseth!
I have two tow vehicles with this type of setup from the factory. You should find VERY specific directions in the owner's manual regarding setting up the load equalizing hitch if the vehicle has the appropriate trailer tow ratings. Each one of my vehicles has a different procedure. One calls for loading the tow vehicle ready to tow, then getting it aligned ready to hitch and turning the ignitition off so that the automatic level feature doesn't try to further inflate the shocks - - then hitch and adjust the weight distribution bars before re-starting the tow vehicle. The other calls for inflating the air springs to 30 psi then following the setup instructions just as with the first vehicle.
Disabling the system by pulling the fuse with either of my vehicles would result in the potential for serious (EXPENSIVE) damage to the automatic leveling system. I will admit that both of my vehicles are older - - a 1975 Cadillac Eldorado and a 1985 Oldsmobile Delta 88 Royale Brougham Luxury Sedan - - so they may be a bit different than the current crop of vehicles with automatic leveling systems.
Good luck with your tow vehicle adjustments.
Kevin
Kevin D. Allen
AIR #827
Dodge manual vs. automatic transmission idahosafari Tow Vehicles 0 02-26-2004 08:52 PM
Air Ride hitch? maznblu Hitches, Couplers & Balls 1 10-10-2003 09:46 AM
Independent Suspension on an AS? LittleRadio Our Community 4 07-07-2003 10:41 PM
Velvet Ride spring shackles? Rusty Bucket Our Community 5 12-25-2002 09:30 AM
2002 Classic 25' suspension? Kistler 2001 - 2005 Classic 7 11-12-2002 02:01 PM
