Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Bambi > 1999 - 2004 Bambi
Old 08-27-2003, 09:05 AM   #1
dtbw's Avatar
Profile:  1999 34' Limited
2002 19' Bambi
Allen , Texas
Any other '02 Bambi LS units out there?
In chasing down the whole 19' Safari LS vs 19' Bambi LS badging, some things have become clearer, others less so. Our unit J514492 is clearly not a standard 19'er and it was made in early Oct 2001 which puts it in the right timeframe to be one of the tricked out 19'ers that Airstream originally badged as Safari LS and then later had the dealers rebadge as Bambi LS.
I am curious if there are ANY other Bambi LS badged units (either spotted or owned). Our dealer did tell us the story of A/S having them rebadge the Safari LS to Bambi LS, but at the time, it did not make much difference to us, so I did not specifically inquire if ours was the unit rebadged (high probability as it had been sitting on their lot for a year when we bought it early last Oct). I am working with A/S to see if they can help ascertain if ours was originally badged as a Safari LS and if so, intend to order the Safari lettering and return it to original factory livery.
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
Past President Heart of Texas Camping Unit
WBCCI # 7548
dtbw is offline   Reply With Quote
Old 08-27-2003, 09:27 PM   #2
yukionna's Avatar
Profile:  Massachusetts
Images: 18
Send a message via Yahoo to yukionna
David -- you know I wouldn't pass by this post without a response!
Here is a rear shot of my 2002 Bambi with the Safari LS badging.
yukionna is offline   Reply With Quote
Old 08-27-2003, 09:36 PM   #3
yukionna's Avatar
Images: 18
And here is a side-view photograph which shows the "Safari LS" badging on the far right and the "70th Anniversary" badging on the left.
Name:	side badging.jpg
Old 08-28-2003, 08:55 AM   #4
dtbw's Avatar
2002 19' Bambi
Allen , Texas
small medallion just on curbside
Nancy,
In your shot of the roadside, I do not spot the small medallion like is on the curbside just behind the refrig access door. Does your unit just have the single small medallion? The medallion at the front of the roadside, is the same as on my unit (both sides).
david
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
WBCCI # 7548
Old 08-28-2003, 09:04 AM   #5
dtbw's Avatar
2002 19' Bambi
Allen , Texas
Rear WBCCI #s
Nancy,
I also thought I would pass along that I scanned and reduced my WBCCI #s. Thought they just looked better a bit lower.
david
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
WBCCI # 7548
Old 08-28-2003, 09:53 AM   #6
Rickk48's Avatar
Profile:
Interesting. My '01 Bambi also has the 70th Anniversary Badge.
Rick Klein
'01 Bambi
'99 Land Rover Disco
Rickk48 is offline   Reply With Quote
Old 08-28-2003, 10:28 AM   #7
yukionna's Avatar
Images: 18
David, [oops] you might be right about the roadside front badge. I came across this photo in my collection and just assumed the front badge was the 70th anniversary badge. I can't confirm it yet as my Airstream is still at the factory! Sorry to raise even more confusion!
Old 08-28-2003, 02:40 PM   #8
dtbw's Avatar
2002 19' Bambi
Allen , Texas
'01 should have the anniversary badging
Rick,
Your Bambi should have the anniversary badging as '01 was the anniversary year. In talking to A/S, they told me that NONE of the '02s should have had the medallions, but some did go out with them.
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
WBCCI # 7548
Old 08-28-2003, 07:36 PM   #9
WayWard Wind's Avatar
Profile:  2004 25' Safari
David I see that you have put your #'s on the unit. Did you have them special made so they can be easliy removed, or did you just give-in & go with the regular ones? We still haven't made up our minds, as to put them on or not, as we like the looks with-out. I admit it's fun to see others & look up who they are & where they're from.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 09-27-2004, 01:04 PM   #10
Profile:
New owner 02 Bambi LS
I know this is a old post but I am the new owner of a 02 Bambi LS I am looking forward to getting a lot of use from this unit. The info in this site helped me make my purchase, what to look for and look out for. Thanks for your help and info.
03springer is offline   Reply With Quote
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 40 10-28-2009 08:07 AM
Recent Bambi owners wanted! rluhr 1999 - 2004 Bambi 82 09-01-2009 09:55 PM
WBCCI and local Units Stougard WBCCI Forum 58 02-28-2006 09:46 AM
Valve stem failure on '02 Bambi dtbw Wheels 12 10-25-2003 11:17 AM
'02 "Safari" Bambi rfield54 1999 - 2004 Bambi 19 08-19-2003 09:46 PM
