Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Bambi > 1999 - 2004 Bambi
Old 01-13-2007, 12:03 PM   #29
rseagle's Avatar
Profile:  2004 22' International CCD
Spotsylvania , Virginia
Images: 33
Originally Posted by RDM16CCD
rseagle
That looks like a good setup - can you tell more about:
1) What did you do with the battery cables to make them reach?
2) How did you fabricate that mounting bracket, and any photos?
3) The cover - any more details, or photos?
I never saw a battery like that but it is exactly what is needed for more capacity, permanently mounted - go taller, not wider!
Hi RDM16CCD,
Here is the link to the current battery manufacturer. Douglas was bought out by East Penn Manufacturing. This is the Deka line:
http://www.eastpenn-deka.com/assets/base/scrubber.pdf
The 9C12 with 228 Ah is a monster!
1. The fabicator just spliced in some longer terminal leads to reach the battery.
2. Get some cardboard or foamcore board and make a mock-up baseplate that fits precisely in the space between the gas cover and jack and rests on the tongue rails. Place battery footprint in the center of the baseplate. Size baseplate to leave about a 1 1/2" to 2" front and back for clearance between the gas bottle cover and jack plate. This will give the fabricator something to work from. I also did an engineering drawing to go with it. You can PM me for that, but it may be a little different for the 16'. He can weld in the L-iron stiffeners and threaded rods for the holdown.
3. The fabricator carefully tack welded aluminum to fit the bracket. Like I said, I had to spruce it up by polishing and adding trim. The aluminum trim and rivets are from Lowes or Home Depot. The International Medallion was from Airstream via my local dealer.
All the photos that I have are posted on my photo page under RSEAGLE.
Hope this helps.
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
WBCCI# 1430
AIR# 4749
rseagle is offline   Reply With Quote
Old 01-13-2007, 12:54 PM   #30
rseagle's Avatar
Images: 33
I guess if price is no object, the $3,898 cost for the SFC A50 and the $79 per 4-Pack of Fuel Cells and the $25 Hazardous Material Shipping Charge wouldn't bother me.
Smart Fuel Cell - POWERS YOUR INDEPENDENCE
I'll guess I'll have to stick with my Honda generator for now.
2004 22' CCD
1997 F-150
WBCCI# 1430
AIR# 4749
Old 01-13-2007, 04:51 PM   #31
Profile:  2007 16' International CCD
Los Angeles , California
Yeah, it doesn't come cheap.. although it does come cheaper then that.
sos10 is offline   Reply With Quote
Old 01-21-2007, 10:44 AM   #32
The EFOY 600 (25W) is $2600. EFOY 1200 (50W) is $3900. EFOY 1600 (65W) is $4500.
10L of ULTRA PURE methanol fuel is $29.
Old 01-21-2007, 04:08 PM   #33
campadk's Avatar
Profile:  2007 19' Bambi
Ottawa , Ontario
Will the 2 6V golf cart batteries fit in the battery box on a 19ft Bambi? Sure doesn't look like it.
Replace the 2 group 24 batteries that come with it with the golf car batteries would require replacing the battery box, from photos below, not sure if there is room?
Group 24 batteries: 10.87 X 6.58 X 9.97
Golf Car Batteries: 10.37 X 7.13 X 11.57
Swapping batteries would add a total of 16lbs to the tongue weight
Has anyone done this mod on a Bambi?
campadk is offline   Reply With Quote
Old 01-21-2007, 08:33 PM   #34
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Yup!
Did it! First, remove the hatch and place the 6VDC golf cart batteries in the box. Give yourself enough room for the cables and use some wood to see what height for the riser you will need. Then have a welder fab the riser from aluminum 'C' channel, rivet it on, spray to match and re-rivet the hatch back on. DONE DEAL! Now, 2 Lifeline 6VDC golf cart batteries.
Lew Farber -Certified Master RV Tech (currently on Forums sabbatical)
WBCCI #1456/VAC (assoc) #1456 AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Adding another Battery to a '72 Sovereign mello mike Batteries, Univolts, Converters & Inverters 2 07-21-2004 10:43 PM
Adding second battery box nickcrowhurst Electrical - Systems, Generators, Batteries & Solar 5 02-13-2004 06:26 PM
CCD 2nd excursion ChrisAich 2003 International CCD 18 07-29-2003 05:34 PM
Adding a second battery... drboyd Electrical - Systems, Generators, Batteries & Solar 3 07-28-2003 01:45 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 09:43 AM
