Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2000 - 2004 Safari
Old 12-14-2002, 04:24 PM   #1
2001 27' Safari
Springfield , Virginia
Smile Problem fixed
Good news. Working with Airstream techs by phone, Parkview RV was told to remove the rear wall electrical outlet box and pull out as much of the TV antenna cable as possible. When they did this, they discovered that the Airstream factory had neglected to connect the splice the feeds signal to the bedroom antenna outlet! Another example of faultering quality control in Jackson Center! Parkview connected the splice and all works fine now. Problem solved.
Lew Brodsky
Springfield, VA
lbrodsky is offline   Reply With Quote
Old 12-16-2002, 08:42 AM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I like this ending!
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Univolt common problem 71tradewind 1970-79 Tradewind 21 06-08-2011 11:36 PM
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 10:05 PM
fixed the icemaker problem PeterH-350LE Airstream Motorhome Forums 5 10-31-2003 05:44 PM
Argosy water fill problem mcneon Argosy Motorhomes 1 10-09-2003 05:30 AM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
