Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2001 Safari
Old 06-24-2002, 12:22 PM   #1
Profile:  2001 27' Safari
Springfield , Virginia
Loud range hood fan
By now, Safari owners are probably hard of hearing if they use the fan over the propane range for any period of time. Airstream chose to provide us with a cheap, one-speed (i.e. LOUD) fan. However, there is a way to cut back on the noise. Contact the range hood manufacturer, Ventline, in Bristol, IN, (219) 848-4491. For about $20, they will send you a wiring kit to convert the fan from its single speed to two speed operation. Good instructions are included to remove, re-wire and replace the rotary switch. You also will be adding a resistor into the switch circuit. The slower fan speed is substantially quieter. The trade off is that you must now use the fan in combination with the light. There will no longer be a fan-only switch setting after you modify the switch wiring.
Lew Brodsky
Springfield, VA
WBCCI #2585
lbrodsky is offline   Reply With Quote
Old 06-24-2002, 12:52 PM   #2
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Cheaper approach
There is a better way if you feel you can tackle a minor rewiring job.
I bought two 5-ohm power resistors (you can get them at Radio Shack or any electronic supply). I put one resistor permanently in series with the fan motor and wired the other resistor across the light switch on the hood so that I have either 5 or 10 ohms in series with the motor depending the setting of what was the hood lght switch. I now have 2 fan speeds, one slightly slower and quieter than the original speed and the other speed slower yet and very quiet. The higher speed moves just as much air now as it did before since the fan is not cavetating.
My light is now wired to the adjacent under-cabinet light so that the switch on that light turns on the hood light in addition to the under-cabinet light. I usually turned both lights on at night anyway.
My total cost was in the neighborhood of $1.00.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 06-24-2002, 01:31 PM   #3
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Lew & John,
Thanks for the information. It's interesting that this is such a little thing that has minimal impact upon price, yet creates a negative impression upon a new owner. Probably this is something that needs to get forwarded to A/S as a product improvement.
I tend not to use my fan because of the racket it creates.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 06-24-2002, 02:32 PM   #4
Pahaska's Avatar
Images: 12
I agree
This is the third trailer vent hood that I have modified. I found the idea in Trailer Life about 10 years ago, so others have had the same problem long before us.
The noisy hood is completely out of character with the rest of an Airstream.
John W. Irwin
Old 08-21-2002, 12:47 PM   #5
gwsullivan's Avatar
Profile:
I took John Irwin's recommendation and added a 10 ohm resister to the hot lead on the fan. It is now quiet enough to talk over and there is enough airflow to open the flap. Cost $1.00 Thanks John.
Jerry Sullivan
'01 Limited
'01 Safari
On The Road, USA
gwsullivan is offline   Reply With Quote
Old 09-26-2003, 06:08 AM   #6
'97 Excella 25
Bob Thompson's Avatar
Profile:  Corpus Christi , Texas
Images: 60
I too, took Johns advice and installed a 1/2 watt 10 Ohm resistor in the range hood fan hot wire on my Award travel trailer. Worked great. Thanks John. When I finally decide which Airstream will replace the Award, you can bet the fan will get the same treatment. My wife is delighted!
Bob Thompson is offline   Reply With Quote
Pingbacks are On
noisy refrigerator fan Turtle 1999 - 2004 Bambi 9 06-03-2004 03:45 PM
Range Hood Vent Cover Chuck Roof Vents, Skylights & Fans 0 08-06-2003 06:31 AM
Exhaust Fan Cat Roof Vents, Skylights & Fans 1 10-04-2002 10:44 PM
HOT Topic for the summer-Air conditioners-Best/worst? thenewkid64 Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-03-2002 04:55 AM
SEO by vBSEO 3.1.0
