Old 01-01-2018, 05:13 PM   #1
Miramar beach , Florida
Wall monitor
1999 safari, water pump works but nothing else shows, replaced monitor and still no lights. Can anyone help
glenmoon is offline   Reply With Quote
Old 01-01-2018, 06:18 PM   #2
2017 27' Flying Cloud
Fort Worth , Texas
Are you plugged in or on battery? You are saying that your display (volts, water, grey, and black are all blank?
billrector is offline   Reply With Quote
Old 01-01-2018, 06:30 PM   #3
2007 22' International CCD
Time to look for a fuse feeding the monitor panel. Also check that the panel is getting power with a multimeter...
rmkrum is online now   Reply With Quote
Old 01-02-2018, 08:18 AM   #4
Wall monitor
Thanks. Water pump works on both batteries and electric
Nothing else lights up
Would this have different fuse for water, dark, and battery
Old 01-02-2018, 08:58 AM   #5
Yup. Typically the monitor panel only has a switch for the water pump. The water pump and the monitor panel each have a separate fuse..somewhere.
I'm dreading failures on mine, as I have NO idea where the panel is actually powered from...
Old 01-02-2018, 06:28 PM   #6
My monitor has water pump switch and buttons to push to check battery and water
No lights come on to check status but pump works
Old 01-02-2018, 08:36 PM   #7
Wall monitor
Yup. Pump is a totally separate circuit from the monitor. Pump will run without the monitor panel having power. Mine works the same way.
Old 01-03-2018, 04:50 AM   #8
Wall monitor
Thanks and will start looking
Old 05-11-2018, 11:05 AM   #9
ljaecks's Avatar
1962 22' Safari
1964 26' Overlander
1965 26' Overlander
Wenatchee , Washington
I don’t if you found the answer yet BUT we had the same problem at about the same time. I ordered a new monitor found on clearance sale. However, it turned out that the problem was the rocker switch went bad. We ended up replacing only the switch and it works great now. :-)
Laura
ljaecks is offline   Reply With Quote
TV/Monitor Wall Mount perryg114 Audio, Video & TV 13 11-04-2013 07:29 AM
Does the Micropulse Monitor Panel Monitor LP? KJRitchie LP Gas, Piping, Tanks & Regulators 5 03-21-2013 02:20 PM
Wall to Ceiling attachment - Head Wall 2003 25' safari Clawdan General Interior Topics 1 11-27-2011 10:01 AM
wall covering??? leather, Wall paper Josh Loki General Interior Topics 1 07-02-2011 10:16 AM
Wall-to-wall carpet alternative mcneon Upholstery, Blinds, Walls & Interior Finishes 9 11-20-2008 01:41 PM
