I remove the vertical panel to gain access to the pump as follows:
Remove the 8 screws from the side and top edges of the panel.
Remove the closet doors using the quick release hinges.
Remove the heating vent grill.
Pull or pry the panel towards the center of the trailer approx. 1/2" until it is up against the vertical trim moulding at each end.
Slide the panel up from the floor enough to gain pump access.
I've done this a couple of times now for winterizing and am still thinking about an access door or panel.
Next time I winterize the trailer, I'll have a decent air compressor so I wont be using antifreeze except in the traps.
Bill Howell
Wappapello, Mo.
2000 Safari 27
2005 Dodge Ram 2500 Diesel
WBCCI #2526
