Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1999 Safari
Old 01-09-2003, 01:12 PM   #1
Raptorrider2001
Raptorrider2001's Avatar
Profile:  Richardson , Texas
Images: 14
Question External Antenae Connection
My 25' Safari('99) has a TV and Phone outlet in the rear bumper
storage compartment. Is this where I would connect a small satellite
dish cable? Would it then feed all of the interior outlets? Thanks
'99 25' Safari
2 Honda 2000i generators
'08 Chevy Duramax
'01 Yamaha Raptor ATV
'07 Yamaha Rhino ATV
2 burgler alarms: Rotweiller and Shepherd
"If you step down to get in, you have to step up to get out"
Raptorrider2001 is offline   Reply With Quote
Old 01-09-2003, 01:30 PM   #2
gwsullivan
gwsullivan's Avatar
Profile:
I will assume your '99 is wired the same as my '01. The coax goes from the rear bumper to an outlet in the living room where it is terminated on a circuit board behind the face plate. This board contains the antenna booster as well as the coax to the rear bedroom. I installed an additional connector on the face plate and moved the coax from the rear bumper to it. This is the connection I use for satellite tv. When I use the antenna I connect the tv back to the original connector.
Hope this helps
Jerry Sullivan
'01 Limited
'01 Safari
On The Road, USA
gwsullivan is offline   Reply With Quote
Old 01-09-2003, 02:07 PM   #3
RoadKingMoe
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
Not sure if the Safaris are different, but the cable from the rear of my trailer goes to a plate in the credenza. The plate has two coax connectors and a short loop of cable between them. Then it goes up to the plate with the amplifier and cigarette lighter.
You insert the satellite reciever connections at the plate in the credenza. When the Winegard TV amplifier is on, it's getting the signal from the batwing antenna. When the amplifer is off, it takes the signal from the sat receiver hooked to the connections in the credenza.
Maurice
AB8XA
WBCCI 5446
The Long, LONG Trailer
Old 01-09-2003, 05:16 PM   #4
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Connecting at that outside point directly from your dish will bring the signal into the trailer. You will then need to connect a satellite receiver to the inside connection and connect your TV to the satellite receiver.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 01-09-2003, 09:50 PM   #5
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
The standard Winguard wall plate is a pass thru for the external connection when the booster is off. If the booster is on it will feed the amplified signal from the antenna, and no signal from the outside connection.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 01-09-2003, 10:05 PM   #6
Raptorrider2001
Images: 14
Thumbs up Thanks!
Thanks to everyone for their help. What a great Forum. Now, if I can just get one of you to find my roof leak....
'99 25' Safari
'08 Chevy Duramax
Old 01-11-2003, 10:25 AM   #7
jcanavera
jcanavera's Avatar
Fenton , Missouri
Images: 143
Satellite hookup update
I've been taken to task by someone who repairs A/S for a living, who is telling me that the amplifier will filter out the voltage necessary from the satellite receiver to LNB on the satellite dish.
Personally I felt that if the antenna amp is turned off the voltage would pass through. I guess the only way to prove this out will be to hook the satellite receiver to the connecter on the antenna outlet inside the trailer, make sure the antenna amplifier is turned off, turn on the satellite receiver and measure if there is voltage present at the outlet in your Safari bumper storage area.
I would do this myself but my Safari is in inside winter storage about 50 miles out of town until March. I'll be working the WBCCI table at the local RV show next weekend and I'll see if I can get some definitive answers from our dealer's folks.
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 01-11-2003, 11:13 AM   #8
RoadKingMoe
Beavercreek , Ohio
Jack, I wouldn't do that. I believe the voltage that powers the LNBs is higher than that which feeds the amp in the batwing. Might toast it.
See page 3 of the Winegard external dish manual
http://www.winegard.com/images/pdf/2451148.pdf
which shows how to hook a satellite receiver into the cable input of their receptacle for the batwing antenna.
In my '01, Airstream has already done this. The cable from the rear of the trailer comes forward to a plate that is hidden in the
rear of the credenza. That plate has two coax connectors. One is the cable from the rear of the trailer, and one goes up the wall to the center connection on the batwing plate.
Airstream ships the trailer with a short coax cable jumper between these two connections in the credenza, so the connector at the rear of the coach can be used for cable TV.
To insert a satellite receiver, you remove the jumper and connect the Sat In input on the sat receiver to one of the two connectors in the credenza, and the TV Out output on the sat receiver to the other of the two connectors in the credenza. It is possible to get them connected backwards, and I forget which is which.
Once it is hooked up correctly, when the amp switch on the batwing plate is out (OFF) the TV out from the sat receiver will be fed to both the coax connector on the batwing plate, and the
coax connector in the bedroom. When the amp switch on the batwing plate is in (ON) both its connector and the bedroom connector will get the signal from the over-the-air batwing antenna.
Hope this helps.
Maurice
WBCCI 5446
Maurice
AB8XA
WBCCI 5446
Old 01-12-2003, 10:55 PM   #9
jcanavera
jcanavera's Avatar
Fenton , Missouri
Images: 143
Maurice,
The Safari doesn't have the cableing set up like you speak about. I think at this point I'll talk to the dealer's service guys on Saturday at the RV show. We will figure this out since I was planning to start carrying a satellite receiver and dish this coming travel season.
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 01-12-2003, 11:02 PM   #10
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Wiring
My International has just the setup Maurice has described. Only difference is that my plate with the cable jumper is right out in the open, above the refrigerator.
I find it odd that they would have done something different on the Safari of the same year as Maurice's.
I haven't actually tried it with a satelite, but that's how my manual reads, also.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Valterra to Thetford connection Craig Waste Systems, Tanks & Totes 28 09-10-2008 07:07 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 04:25 PM
Where is the tachometer connection? AccessMaster Mechanics Corner - Engines, Transmission & More... 13 06-29-2003 06:26 PM
TV Antenae 79 Soveriegn Gordon Watt Audio, Video & TV 10 02-11-2003 06:55 PM
Flush out connection JLD Waste Systems, Tanks & Totes 2 01-04-2003 10:06 PM
