Old 04-22-2015, 07:13 PM   #1
outbackbob's Avatar
1999 25' Safari
Clarksburg , California
Dual battery box modification
Trying to change out my group 27 battery to two golf cart 6 volts to increase my amp-hour capacity. Weight and limitations to fit a dual 6 box are brutal.
Working on having a fabrication shop form a 10 gauge channel that will be welded to replace my OEM bracket. More to follow.
ID:	236850   Click image for larger version
ID:	236854   Click image for larger version
Regards, OutBackBob
outbackbob is offline   Reply With Quote
Old 05-01-2015, 03:18 PM   #2
outbackbob's Avatar
1999 25' Safari
Battery Box completed
Completed battery box pictures.
ID:	237536   Click image for larger version
Regards, OutBackBob
Old 05-01-2015, 03:29 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Looks good!
Old 07-29-2015, 05:09 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
tongue weight change?
Have you had the opportunity to weigh since you made this modification? Did it increase the tongue weight substantially?
What dimension battery box did you get?
I'm considering doing the same thing.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 07-30-2015, 07:31 AM   #5
outbackbob's Avatar
1999 25' Safari
Haven't weighed tongue since modification yet but I'm guessing I added about 83.4 lbs.
Battery box details $49 plus shipping are here:
Century Plastics: White Heavy Duty Battery Box - (part#: GCE-G)
The batteries weigh 66.7 lbs. each and were purchased at Costco @ $167.98 each.
Reserve capacity-20H Golf Cart 6V-GC2 Interstate each = 232
Reserve capacity-25H for the one 27SMR Interstate 12 volt = 160
I added 83.4 lbs. tongue weight and more than doubled my reserve battery capacity.
Regards, OutBackBob
Old 07-30-2015, 07:33 AM   #6
outbackbob's Avatar
1999 25' Safari
Interstate 6 volt golf cart battery details:
Interstate Batteries | Deep-Cycle 6-Volt Battery | RV Batteries | Camper Batteries
Regards, OutBackBob
Old 07-30-2015, 09:02 AM   #7
Mission , Texas
Slightly ugly, but a PO of mine put two batteries on the rear bumper. So mine has three. Someday I'll do the math for how many AH that translates to so solar can be added.
nrgtrakr is offline   Reply With Quote
Old 07-30-2015, 05:25 PM   #8
outbackbob's Avatar
1999 25' Safari
Agreed, an aluminum battery box is in the works next.
Regards, OutBackBob
Old 07-30-2015, 09:46 PM   #9
54 Flying Cloud
KrisE MN's Avatar
1967 20' Globetrotter
1954 22' Flying Cloud
Grand Rapids , Minnesota
There are some nice ones. Around 200. Most look like truck tool boxes. http://www.amazon.com/gp/aw/d/B00V8N...minum+dual+box
Liftco makes one without diamond plate. http://www.amazon.com/gp/aw/d/B00LXF...y+box+aluminum
KrisE MN is offline   Reply With Quote
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box 59as Airstream Classifieds 0 09-19-2014 11:01 AM
Battery box and battery location(s) ehodg66 Batteries, Univolts, Converters & Inverters 4 04-22-2014 07:39 PM
Battery Box Modification Options Ridgerunner3 Batteries, Univolts, Converters & Inverters 5 10-09-2013 04:28 PM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
