Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1999 Safari
Old 04-03-2006, 08:19 PM   #29
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
That's why I chose to be a dealer for Zip-Dee. They stand behind their products. But then, it has been my experience that Carefree does also!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 04-03-2006, 10:25 PM   #30
Profile:
Broken arm
We have a broken arm (it fell off!) on our 2004 Zipdee. Who should I call, Airstream or Zipdee? Any recommendations? Tom
Tom and Frank
Evanston, Illinois
2004 Safari 28 ft Slideout "Lucy" 4 HI CAMP
2004 Ford Excursion 6.0 PSD PWRSTRK,
and Brittany, the Nova Scotia Duck Tolling Retriever
PWRSTRK is offline   Reply With Quote
Old 04-03-2006, 10:31 PM   #31
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 35
Call Zipdee! http://www.zipdeeinc.com/
Good news for you, they are located down the block (25 miles) from you in Elk Grove Village, IL.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 04-03-2006, 10:36 PM   #32
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Tom,
Zip Dee is right down the street from us in Elk Grove Village.
Doesn't get any better than that!
Oops...that's already been posted.
Old 04-04-2006, 12:05 AM   #33
Profile:  1992 34' Limited
Falls Church , Virginia
Triangulation is working!
Eric -
Slowly getting a bead on your location. Another clue - 'Elk grove village', ' ZipDee around the corner', '5 minutes away'.... Mr Watson, if you please...
Just funning!
Always enjoy your posts. Always good reading - especially when I get closer to figurin' out where you post from.... Too much time on my hands huh?
Ciao!
Axel
SilverToy is offline   Reply With Quote
Old 04-04-2006, 07:45 AM   #34
duo
'69 Caraval '98 Safari
Profile:  1969 18' Caravel
1998 25' Safari
Starkville , Mississippi
Thank you, Lew Farber, for the reply, I can see how that works now. But can I leave the awning "feet" attached to the trailer and just pull the awning up into place? That way would be a lot easier. Thanks again. Jac
duo is offline   Reply With Quote
Old 04-04-2006, 08:13 AM   #35
Chaplain Kent's Avatar
Profile:  Wauwatosa , Wisconsin
Originally Posted by JaceBeck
Final word. A&E has shipped all new hardware and a replacement rolller tube at no charge. Absolutely great to work with, no questions asked, just how can we take care of the problem and keep you satisfied. Really exceptional service.
I have had this same experience with A&E but after the third time in one season it became bore to stand in the dealer's lot while they replaced everything. I tried the awning yesterday and it will not open, time for new arms again. Fortunately I talked with the rep at a show and he said he would have an extra set sent to the dealer just in case. He also stated that he wished A&E never got involved with Airstream. I put a Carefree on my Tradewind and just loved it. It was easy to operate and never gave me a problem. It was from this same dealer Roskopfs in Milwaukee and they always stand behind what they sell.
Chaplain Kent
WBCCI #7235 - Former VAC
1982 280 Turbo Diesel Motor Home (Chummy)
http://goodsamclub.mytripjournal.com/Chummy
Chaplain Kent is offline   Reply With Quote
Old 04-25-2006, 12:11 PM   #36
Waterman's Avatar
Profile:  1999 25' Safari
Hillsboro , Oregon
A&E Woes
Just read all the posts on this thread. I've got a '99 25' Safari with the A&E awning. My rear lower 'foot' is bending and the front looks like it will start next. Last weekend the upper rafter bracket broke and at first I thought, at 7 years old, no problem. WRONG! Dometic, A&E and even AS don't have ANY parts for this piece of junk. At this point, my only option is to remove the entire awning from the trailer before any hardware fails and damage to the coach occurs. Anybody removed their awning? How difficult is it, it looks pretty straightforward - take the hardware off, then slide it out of the rail. Am I missing something? Thanks for any replies!
Waterman is offline   Reply With Quote
Old 04-25-2006, 02:36 PM   #37
pmclemore's Avatar
Profile:  1998 31' Limited
Walkerton , Virginia
My 97 has the A&E as well. Haven't had any problems except the locks don't work. Feet seem to be fine.
However, if there is one thing I'll take away from this thread, it is to save my money so I can afford a zip dee when the time comes.
Pat
pmclemore is offline   Reply With Quote
Old 04-25-2006, 02:54 PM   #38
Waterman's Avatar
Hillsboro , Oregon
I hear ya!
Ditto on the Zip Dee. I removed the A&E - did not want to have another part break while on the road and possibly damage the coach. I actually removed, re-riveted, resealed and cleaned up in about an hour. Pretty easy job. Hope I can put the Zip Dee on as easily when I finally am able to afford one as a replacement. I'll miss having an awning a lot but not the worry of a part failure. The rear foot on mine was ready to completely shear off. Thank goodness it didn't happen while we were towing.
Old 04-25-2006, 02:56 PM   #39
Gen Disarray's Avatar
Profile:  1968 24' Tradewind
Lawton , Oklahoma
Makes me feel a bit better about the dometic stuck to the side of my coach
Rodney
The trouble ain't that there is too many fools, but that the lightning ain't distributed right.- Mark Twain
Visit my photography page at:http://www.pbase.com/professor_chaos
or my new travel site
Synapticstorms (under construction)
Gen Disarray is offline   Reply With Quote
Old 04-25-2006, 05:31 PM   #40
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
I assume this is tongue in cheek I have Carefree on mine and they aren't any better on the the service end. I am still trying to figure out which PO decided to ditch the orginal Zip Dee's for the Crappee awnings. Unfortunately Zip Dee seems to be the only one that has really produced a long lived awning for the Airstream. Eventually I will return my unit to the ZippDees but it is a ways off.
Aaron
WBCCI #2449 AIR #2495
Pingbacks are On
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
Replacing Awning Arms beachmpk Awnings 7 10-05-2004 01:28 PM
Ground bracket solution for awning yukionna Awnings 3 10-05-2003 09:09 AM
How do I properly set up an awning? BrianB Our Community 1 05-13-2003 12:44 PM
Awning Repair cesurman Awnings 0 08-16-2002 11:57 AM
SEO by vBSEO 3.1.0
