Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1966 - 1968 Safari
Old 02-03-2003, 09:11 AM   #1
Window replacement issue
When replacing the oval rd lower fwd window just infront of the entry door, how do you replace a broken glass? I can see the frame has to have the rivets drilled out. I don't want to put "pop" rivet as replacements. I want to use solid al rivets that will appear stock. How will I get to the backside of the wall to buck the tails?
Thanks..........Dave
davespann is offline   Reply With Quote
Old 02-03-2003, 09:49 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Lutz , Florida
Images: 21
I cannot answer the glass replacement question, but on the rivet front the answer is to use olympic rivets. They work like a pop rivet, but can be finished to look like the original solid rivet. It does require a tool to do the finishing, but it is worth the $$.
The Olympics are what is used for all repairs so that inner skins do not need to be removed.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 09-09-2008, 02:00 PM   #3
pagosa springs , Colorado
Is the glass better than the plastic glass that some use for the windows?
gc24 is offline   Reply With Quote
Old 09-09-2008, 02:43 PM   #4
The window is replaced with a new sash and glass, with Olympic rivets and vulkem sealer.
If you use plexiglass, it will crack and craze in short order.
Also, the gray gasket is not available from Airstream.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-09-2008, 04:20 PM   #5
Thanks.
Window Replacement bubba99301 Windows & Screens 9 03-21-2012 05:32 PM
Window replacement Tin Can Windows & Screens 10 04-09-2006 10:15 AM
Window replacement JeffTerry Windows & Screens 7 08-23-2005 07:08 AM
Help! Window replacement. Navigator Windows & Screens 2 11-12-2003 02:59 PM
