Old 07-24-2008, 10:53 PM   #1
59 GlobTro's Avatar
1959 18' Globetrotter
1975 31' Sovereign
1967 22' Safari
Eaton , Colorado
What's behind Door #1? (pic needed)
We have a '67 Safari whose PO somehow reconfigured the furnace to where there is no access to light it. The face of the furnace door is stuck flush behind the cupboard post now. I would like to put it back to its original state, but I'm not sure what it should look like. I know that most of us usually don't take pictures of the "behind the scenes" areas of our trailers, but if anyone has a picture of the original configuration/placement of a '67 Safari furnace (installed and inside the galley), would you mind posting it?
Will
Lori & Will
1959 Globetrotter "GlobTro"
1967 Safari "Dusty"
1968 Safari "Cheyenne"
1975 Sovereign "Lovey"
1972 Ambassador "For Sale"
1975 Romany "Parts"
1970 Overlander "Parts"
1968 Ambassador "Larry" (for parts)
59 GlobTro is offline   Reply With Quote
Old 07-25-2008, 05:35 PM   #2
59 GlobTro's Avatar
1975 31' Sovereign
1967 22' Safari
Eaton , Colorado
OK, here's a picture of what I'm dealing with... Does anyone have any suggestions?
Will
Lori & Will
1967 Safari "Dusty"
1975 Romany "Parts"
Old 07-25-2008, 06:54 PM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The most expedient solution is to take a saw to the lower part of that post. You could build a frame around the furnace for the post to brace on, and make the cupboard doors overlap, one over the other.
Old 07-25-2008, 07:55 PM   #4
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I would make the post removable. Maybe a screw top and bottom. Once the furnace is lit the pilot will stay on.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 07-25-2008, 09:38 PM   #5
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
almost oops!
We are getting ready to put cupboard doors on the kitchen sink cabinet, and had it all measured out and planned.......then I saw this post, and sure enough, when I went out to look, the center post would have been right in front of the door of the furnace.....this would have ticked off the resident carpenter no end if he had done that. Thanks for this post, just in time!!!!! Rearrangements have been made.
Jim and Sandy
"To know is nothing at all. To imagine, is everything." --Albert Einstein
http://chaosinature.blogspot.com/
Isadora is offline   Reply With Quote
Needed Bargman Door lock yoderconsult Doors & Locks 6 03-24-2010 10:56 PM
'67 outside door handle needed garyk1970 Doors & Locks 21 02-08-2008 03:29 PM
1979 door lock needed! kammycats Doors & Locks 3 06-08-2005 08:35 AM
Help!! Refrigerator Access Door Needed! Melissa Hamilton Exterior Storage Compartments & Access Doors 13 01-19-2004 04:03 PM
Door edge extrusions needed mcneon Cabinets, Counter Tops & Furnishings 2 10-28-2003 10:17 AM
