Old 03-15-2012, 07:47 AM   #1
1968 22' Safari
Waco , Texas
What size door?
Okay, I need a place to put the 68 Safari Twin 22 footer and so my wife is giving me a new metal building. Now, gotta come up with measurements. How tall is my Airstream? I eyeballed it at a little over 9 1/2 feet so figure a 10 high door X 10 wide. Anyone have the specs sheet with the height listed? I don't have it. Would sure appreciate any help. I currently have the older AC unit on top and will replace it with a newer (lower?)
Skywriter
Skywriter is offline   Reply With Quote
Old 03-15-2012, 07:53 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The height will vary depending on the angle of the axles, tire size and type of AC unit on the roof. A 10 foot door should accommodate 99% of all Airstream trailers.
Richard
Old 03-15-2012, 08:00 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Lay light board like a 1x2 across the top of the air conditioner shroud that sticks out beyond the side of the trailer. With the board held level measure to the ground. Add 6" to the measurement just to be on the safe side. You should be good to go.
Old 03-15-2012, 08:19 PM   #4
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I would go a minimum of 12'x12'. It will be much easier to get in and out. The difference in cost for the bigger door is nothing compared to the first scratch in the side of the trailer.
Cheers, Dan
Smartstream is online now   Reply With Quote
Old 04-30-2012, 03:41 PM   #5
1968 22' Safari
Waco , Texas
Howdy All! Sorry it took so long to get back, but I was busy helping with the construction of a 24X 30 metal building for Kampy, my 1968 22' Safari Twin Airstream. I ended up putting in two 10 X 10 roll up overhead doors: one at each end in a drive-through arrangement. And I now have Kampy under cover and I am ready to tear into the floor. The inside has been completely removed. I suppose the shell removal is next. Sure wish there were an easier way to get rid of the nasty smells under the floor and to not have to replace all the floor. It is rotted out around the back and where the water heater was and also one place up by where the refrigerator was.
Skywriter
door handle susans69 All Argosy Trailers 26 05-30-2017 10:23 PM
Anyone know where to find the outside access door hinges? Roothawg Vintage Kin 10 05-13-2012 04:21 PM
Soon to be for sale. What's it worth? garth66 Trailer Values 7 03-15-2012 08:18 PM
Rivet Type - Door Strike Plate bganso Doors & Locks 2 03-14-2012 09:33 PM
