Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1966 - 1968 Safari
Old 10-20-2011, 10:53 PM   #1
1967 22' Safari
Stevens , Pennsylvania
What is this thing?
'67 safari.
It's on top of the main frame rail near the tongue. It's 2 or 3 in. diameter and spring loaded. What's it for?
Evets is offline   Reply With Quote
Old 10-20-2011, 11:27 PM   #2
RGates
Randy Gates's Avatar
1968 20' Globetrotter
Thousand Oaks , California
I believe it is the inside portion of an old leveler. The 2 floating levels would sit in a plate on top covered with a plastic cap. They are still sold today at any trailer store.
Regards,
Randy
Randy Gates is offline   Reply With Quote
Old 10-21-2011, 07:11 AM   #3
1977 Argosy 24
Milltown , Wisconsin
What is the diameter of the round plate?
ventport is offline   Reply With Quote
Old 10-22-2011, 10:03 AM   #4
1967 22' Safari
The top plate is 2 7/16
The bottom plate is 2 13/16
There are 3 fairly stiff springs in between.
I've seen those 2-way levels. I can't imagine this is part of one of those, but so far, I can't come up with a better explanation
Old 10-22-2011, 10:26 AM   #5
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
I believe the 3 screws & springs let the user calibrate the base so that this level would match a bubble level placed in the fridge. Once adjusted, the user only had to drive up on boards and use the tongue jack while watching this level. No need to run in and out to check how level the fridge was.
AIR 47751
Silver Goose is offline   Reply With Quote
Old 10-22-2011, 03:34 PM   #6
1967 22' Safari
Well, that makes sense. Thanks.
Wild Thing :: 2005 Airstream Classic DL46 Airstream Registry Discussions 0 08-19-2011 08:31 AM
door latch thing Hardworking Doors & Locks 0 08-17-2011 01:11 PM
Scared Myself - That's Probably a Good Thing! Fly at Night Our Community 6 06-13-2011 12:48 PM
