Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1966 - 1968 Safari
Old 02-22-2009, 10:23 AM   #1
Profile:  1972 29' Ambassador
1968 22' Safari
Tyler , Texas
What happened to my '68 Safari 12v power?
Months ago I replaced the Univolt in my '68 Safari with an 45W Intelipower converter. Everything was working until today. I've got shore power AC, but the 12VDC supply suddenly went dead! It acts like a fuse is blown, but I can't find the fuses--does anyone know where they are? (My AS is the "double" with the fold-up dinette table.)
26.982 amu is offline   Reply With Quote
Old 02-22-2009, 10:27 AM   #2
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
My 9245 has two fuses that are located next to where the power cables (DC) attach to the unit. The unit will also shut down if a short circuit is detected or it gets too hot.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 02-22-2009, 01:13 PM   #3
1968 22' Safari
Tyler , Texas
What do I do to reset it? I checked the fuses and they both look good (mine is a 9145). The unit was not hot, and if there is a short it appeared out of nowhere.
Old 02-22-2009, 01:45 PM   #4
Phoenix , Arizona
Images: 62
Pull all the 12 volt fuses and measure the voltage to the battery with shore power and without. If it is the same your converter is not working. It may have gone bad. As good as these units are they do sometimes fail. Also check the outlet the converter is plugged into for power.
Richard
Old 02-22-2009, 01:50 PM   #5
Profile:  1968 22' Safari
Baton Rouge , Louisiana
Mine were inside the Airstream Power Panel, no clue if they could be somewhere else.
truc_05 is offline   Reply With Quote
Old 02-22-2009, 05:31 PM   #6
1968 22' Safari
Tyler , Texas
Truc 05, if you could give me a little navigation on where the "power panel" is, I would be grateful. I'm at wit's end trying to figure this out. It's not the Intelipower unit--I tried switching with a brand new one, still no 12vdc in the cabin.
Old 03-07-2009, 06:44 PM   #7
1968 22' Safari
Tyler , Texas
Found the offending fuse!
Today I followed a tip from Aggie81 and sent a grandchild into the cramped space between the battery and the sink to find the fuses--and there they were! I was just too fat and stiff to find them--two 30A glass fuses just above the main power breaker. It was an easy fix, and now I've got 12V power again.
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 11:58 AM
Sharp Aquos 12v power cord Camp-Dog Electrical - Systems, Generators, Batteries & Solar 3 01-19-2005 05:29 PM
No 12V Coach Power swebster Airstream Motorhome Forums 5 08-03-2004 04:07 PM
12V power loss sladew Electrical - Systems, Generators, Batteries & Solar 2 08-05-2003 05:47 PM
No 12v Power wcdelorme Electrical - Systems, Generators, Batteries & Solar 13 05-11-2003 10:53 AM
