Here's the lower corner detail.
note the seam binding material that gets sewn into the hemmed edge. Also the curtain has a total of 4 snap fasteners. The male parts should still be on your shower walls..
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
I checked InlandRV 's site and the tabs on it are not the same -think they are regular curtain tabs.
I have seen them on Ebay twice before but not rercently.I counted 13 required.
Murray
AIR #189
Help! I know this thread hasn't been active for quite some time, but I sure hope there is someone who can help me with this.
We are beginning to restore a '68 Safari. I have looked at the bath/shower repeatedly, and I can't figure out how the shower curtain was ever supported. There is no evidence of a rod of any kind to suspend the curtain from by the "hooks" that I saw pictured here.
Any suggestions?
Sally and Tom
Yeah, same here. We wound up putting together a non-original setup (withouth having to drill holes, thank heavens!). Someday we'll find somebody nearby with an original setup that we'll be able to examine and then redo ours.
Lynn
Any suggestions?
Sally and Tom
The 'hooks' pictured run in a aluminum track that is contoured and attached to the ceiling endcap. At least that's the case for '67- not sure about a '68.
Go to my photo gallery and you should find a picture of the curtain shape.
Murray
AIR #189
Thank you for the information. Is there any way that either of you could post a picture of the curtain support? And, is there a way that I could bribe you into making a pattern for me Tin Hut? Newspaper taped together is a fine media for it, and I will gladly pay the postage. And, where do I buy the tabs for the rod, or the rod for that matter? Is that something that Airstream would still have in stock? We have a few holes in the plastic to show where the original rod was attached. My DH will repair them, and then we can start from scratch, once we know what to use.
TomKat:
Scroll down in this thread to see the pics and detail of the curtain. I'll get you a shot of the ceiling guiderail which is about a 1/2 in wide channel for the tab head to run in. Not sure where you'll find similar. Velcro might be a suitable option for you . You could place about 6-8 one inch strips on the ceiling and some on the curtain to match. I'm assuming your set-up is the same as my '67.
Murray
AIR #189
creampuff,
If you go to: www.go-rv.com
Then, type in a state's name...look for a dealer(almost any will do) and then go to page 195.
you should be able to find the curtain guides you need..
ciao
53FC
__________________ WBCCI 5292 AIR 807 NEU #64 New England Unit
TomKat:
Here's a picture from the floor level. You should see rivit holes where your track used to be.
Murray
AIR #189
creampuff,
ciao
53FC
Right on 53FC. The tabs are a few pages back. not sure if that ceiling track is small enough as they don't give dimensions and it only comes in wht or brwn. not mill finish.
Murray
AIR #189
I have a vinyl covered accordian type shower curtain that has some snaps on it. It is split in one section and is a bit faded. I want to stick to originalish features when possible, but am looking for opinions/suggestions on my thoughts......Should I try to remake a replica, or maybe it would look even cooler if I had a stainless curved shower bar and made a curtain with a weighted bottom.....Hmmmm
Bathroom in now stripped and in the fiberglass repair/gel-coat process....
Amy
Amy, It really boils down to what you want. The vinyl accordian type is what I too have on my shower for a surround. If original look is what you want then start looking for a vinyl material that will somewhat match your bathroom color (you may not find anything exactly like your current color). Or perhaps you want to update your trailer sightly to give you a better fit for your own style and better performance than the old technology that thought up the original shower surround accordian that you have now. Either way it is what you decide to go with that will influence what you place in the shower area. You could even get creative and use some of the new top track that is used for shower curtains on old/new clawfoot tubs that now have been modified to use a shower with and mount that to hang a regular shower curtain from. It Is really what you want and are willing to try in your trailer as to what you choose. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT FORUMS MEMBER SINCE 12/16/2004 AIR#7110
"My tire was thumping, I thought it was flat! When I looked at the tire... I noticed your CAT!" Burma Shave
Not having anything other than pictures on this sight to look at, I decided to make my own. I guessed the approximate width of each folding panel and went for it. I used a corrugated plastic panel(normally used for signage), a vinyl shower curtain(for inside), And a nylon shower curtain(for the outside). Not wanting to be too windy I'll stop here and just attach pics. BTW I have a'68 safari.
