Old 06-19-2019, 06:45 PM   #1
1968 22' Safari
ALhambra , California
searching for flat blue boy
My '68 Safari waste drain is only about 8 in off the ground. Having trouble finding a blue boy just for gray water that's lower than that. Any recommendations?
neetie sweet is offline   Reply With Quote
Old 06-19-2019, 07:12 PM   #2
mikeinca's Avatar
2018 30' Classic
Santa Rosa , California
I have a 5 gallon blue boy that can lay flat and the container portion is less than 8" tall (the very top of the hose connection is 8.8"). I like the smaller size because it's easy to manage in and out of the truck when full and is big enough to take the edge off the gray tank with a couple of trips to a dump location without having to move the trailer. If you think the size is ok it might work for your situation. It's available on Amazon:
“The good thing about science is that it's true whether or not you believe in it.”
― Neil deGrasse Tyson
2018 30' Classic Twin
2017 F250 4x4 6.7 max tow Platinum
200W portable solar
240Ah LifePo4 upgrade
mikeinca is offline   Reply With Quote
Old 06-19-2019, 07:13 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Moving the blue boy downhill, away from the trailer, and using a longer hose, will take care of the height problem.
I carry a 25' blue hose for this purpose, and use it only for draining gray water.
I use a 10 gallon tote for both of my trailers. About 85 lbs when full is more that I want to pickup and load on the truck.
ps:
If you decide to use a longer hose, remember it will not drain well unless the second inlet to the blue boy is open so that it will vent as water flows in.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 06-19-2019, 07:58 PM   #4
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Look for the 15 gallon "tent camper tote-tank" from Barker. It is less than 8" thick, but otherwise 30" x 33". It is the lowest profile one I have found.
One source:
https://www.amazon.com/Barker-Manufa.../dp/B000BGM8A8
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 06-20-2019, 02:27 PM   #5
JRF0st3r's Avatar
1967 22' Safari
West Fork , Arkansas
blue tank
Got my 15 gallon 6" high tank from VTS. Full, the tank can weigh 140 lb. To empty it, I stole an idea from this AF site using a 12V cylindrical pump that fits into the tank with a hose connection to an empty 15 gallon tank left in my truck bed. This allows dumping the second tank by tilting it over with a hose going tot sewer dump. OK, I'm too olds and lazy to wrestle with 140 lb.
JRF0st3r is offline   Reply With Quote
Boy Oh Boy! my new '56 Flying Cloud! urbanfood 1956 - 1959 Flying Cloud 171 06-07-2018 07:14 AM
What is the best size Blue Boy tank? silverback Waste Systems, Tanks & Totes 55 05-28-2011 11:04 AM
Best size blue boy tote? Lumatic Waste Systems, Tanks & Totes 23 06-14-2010 05:29 PM
thetford or blue boy or something better? Karterlin On The Road... 4 09-08-2009 10:03 PM
Oh boy, Oh boy till Our Community 19 05-05-2005 07:26 PM
