Old 08-20-2018, 11:21 AM   #1
1968 22' Safari
Jamul , California
Routing of land power line
Still working on my 1968 Safari, just finished plumbing bathroom and about to build cabinets which will contain electrical box and wiring. I need advice on how to route the plug in 30 amp wire from the electrical box inside the trailer to the outside of the trailer. If I just run it out the back removable access panel then I can't put panel cover back on while plugged in,allowing all sorts of stuff in. How did Airstream do it originally? Considering mounting exterior female connector but I'd rather not cut hole in skin if I don't have to.
Name:	our airstream.jpg
ID:	320386   Click image for larger version
Name:	rear panel.jpg
bsaa10bill is offline   Reply With Quote
Old 08-20-2018, 12:35 PM   #2
2007 22' International CCD
I understand the reluctance to punch a hole in the shiny aluminum. However, the best bet is to install an external female socket.
There are several types available. I'm using the SmartPlug 30 amp system
Example: https://www.amazon.com/SmartPlug-B30...artplug+30+amp
Marinco or Furion is another brand in use, twist-lock design.
I prefer the SmartPlug system because it fits better, does not overheat, and is very tidy looking. Designed for use on boats. Search forums for "SmartPlug" for more data...
Modern Airstreams have the sewer, water, electrical, and Television ports at the streetside rear corner for convenience, all with external connections.
Old 08-20-2018, 01:19 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Inside the rear bumper storage, there should be an opening near the extreme left (drivers) side corner. If I remember correctly, about a 1" hole with a grommet.
The power cord would have gone through that opening. From there I've see the connection made two ways. The power cord will either go all the way to the electric panel, or there will be a junction box in an accessible location where the power cord joins to a 10 gauge (Romex) NM cable that runs to the electric panel. If you are doing all new, you could mount a junction box inside the bumper storage area.
Originally, the power cord would be coiled and stored inside the bumper area.
I'm in the school of no new holes. Hooking it up inside eliminates an exterior connection point and the associated problems, and no one can roll up your cord and take it with them without cutting it.
Alan
Old 08-20-2018, 01:34 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
There is a drawing of the electric layout in the Owners Manual on page 65.
You can download it here>
https://www.airstream.com/wp-content...-0004.085c.pdf
Alan
Old 08-21-2018, 12:23 PM   #5
JRF0st3r's Avatar
1967 22' Safari
West Fork , Arkansas
Our '67 Safari came with a "mouse hole" cut into the access hatch cover for the shore connecting cable but we preferred to keep mice out. Our solution was to drill a hole in bottom of rear utility access trunk to route cable into bumper trunk where the cable is coiled for storage or routed through a hole in the bottom to connect to the 30 amp AC outlet.
JRF0st3r is offline   Reply With Quote
Old 08-21-2018, 12:38 PM   #6
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
The 67's had the "mouse hole door"as mentioned above. On my 68 Tradewind the power chord enters the trailer on the curb side through a hole in the floor right under the breaker box which is mounted on the wall just to the right side (looking at the rear hatch) about 8 inches in from the opening of the rear hatch. The chord exits the trailer into the bumper trunk. I considered installing an external socket like the new trailers have but I wanted to keep things original and after 9 years and lots of use I'm glad I did it the way I did. It is simple and one less connection to have potential issue with in years to come. I can send you pics if you need them, just PM me.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-21-2018, 01:03 PM   #7
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 71
Originally Posted by rmkrum View Post
I understand the reluctance to punch a hole in the shiny aluminum. However, the best bet is to install an external female socket. There are several types available. I'm using the SmartPlug 30 amp system
Agree - drill the hole and mount the 30A SmartPlug.
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
gklott is offline   Reply With Quote
Those with the upgrade: Hydraulic Actuator Wiring and Brake Line Routing kry226 Brakes & Brake Controllers 10 04-22-2013 02:19 PM
Propane line routing issues - Argosy MH bkahler General Motorhome Topics 12 03-29-2013 07:47 PM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 11:16 AM
