Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1966 - 1968 Safari
Old 12-06-2005, 08:24 PM   #1
Profile:  San Diego , California
Rear access panel
Is there a way to rout the fresh water hose and electrical cord connections so that you can close the rear access panel? Is there a path to the bumper compartment where the sewer hookup is?
mpumphrey04 is offline   Reply With Quote
Old 12-06-2005, 08:30 PM   #2
StingrayL82's Avatar
Profile:  1971 31' Sovereign
San Angelo , Texas
Images: 37
mpumphrey04 has a 1967 Safari, by the way. I've tried to help out, but my knowledge is limited to my 1971. Can anyone with a 1967 help?
Frederic
SFC Frederic Lynes
1971 Sovereign International
2004 F-350 King Ranch
EX-WBCCI # 8371
AIR # 8239
StingrayL82 is offline   Reply With Quote
Old 12-07-2005, 08:54 AM   #3
47WeeWind's Avatar
Profile:  1948 16' Wee Wind
1964 19' Globetrotter
Denver , Colorado
Images: 13
Hi: I don't know if your 1967 is the same, but my 1964 19' Globe Trotter has a small rectangular trap door towards the streetside bottom that hinges down from the floor of the rear bumper storage compartment. Opening this trap door allows me to run my electrical cord and sewer hose out, and city water connection in, through the bottom while keeping the top access panel shut. Your year might be different, however.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Charter Associate Member FCU
Airstream Life "Old Aluminum Adventures"
47WeeWind is offline   Reply With Quote
Old 12-14-2005, 12:51 AM   #4
BIGED52's Avatar
Profile:  1967 22' Safari
MILAN , Illinois
Rear Access Panel
My 1967 Safari Has The Same Small Rectangular Door (that Is Spring Loaded) On The Street Side Bottom Of The Rear Access Panel. It Stays Closed By The Spring When Not In Use And The Power Cord And/or Hoses For Fresh Water And Sewer Hold It Open When The Access Panel Is Installed. Ed
BIGED52 is offline   Reply With Quote
Old 12-14-2005, 09:58 AM   #5
till's Avatar
Profile:  1967 26' Overlander
1968 26' Overlander
Lisle , Illinois
Images: 108
Send a message via Yahoo to till
The sewer hose drops out of the bottom of the bumper storage compartment. There is a trap door that has two speing clips that keep it in place when not in use.
Tedd Ill
AIR#3788
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 12-18-2005, 01:55 AM   #6
I found the small spring hinged door in the rear access panel, thanks. This will certainly help keep the rats from returning and the heat from leaving.
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 09:28 PM
Solar Panel Installation 69Overlander Generators & Solar Power 23 11-19-2002 10:25 AM
replacement panel maznblu Ribs, Skins & Rivets 4 09-18-2002 06:45 PM
Dented panel replaced Jim W Ribs, Skins & Rivets 1 07-08-2002 08:07 PM
