Old 02-27-2012, 09:27 PM   #1
1967 22' Safari
bolton , Ontario
looking for picture of furnace wires coming from trailer wall
Hello,
I am trying to find the correct wires to attach to my new furnace. Old furnace was already missing so I'm not sure of these wires. Here is a picture, i have tested them and they are 120v. Can someone who has same model show me a pic of what it should be like....
thanks in advance,
paul
pablobagus is offline   Reply With Quote
Old 03-02-2012, 06:22 PM   #2
Hatari
Jack McAllis's Avatar
1967 22' Safari
Gainesville , Georgia
Paul,
Mine had the furnace still installed when I bought it but I tossed it right away. My wiring is still in place though and I'll see about getting you some shots of it. I think I labeled it once I removed the furnace. I can tell you the darker fabric braided wire was to the thermostat. I know that because I also removed the entire interior and when I took down the wall/bulkhead where the thermostat was mounted that darker braided line went into the thermostat...AC was similar and on a separate circuit/thermostat. I'll see about sending photos tomorrow.
Jack
Jack McAllis is offline   Reply With Quote
Old 04-14-2012, 08:27 PM   #3
DFlores's Avatar
1968 22' Safari
What furnace did you buy to replace orginal, I have the original. Will try to post pictures. The only issue I see is that my furnace connects to a box that says "Bat +" and "Bat -", suggesting lower voltage connections.
ID:	155792   Click image for larger version
DFlores is offline   Reply With Quote
Old 04-14-2012, 08:37 PM   #4
DFlores's Avatar
1968 22' Safari
I just checked my wiring diagram and find that the furnace is fed from the low voltage distribution panel.
Old 04-15-2012, 08:26 AM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The furnace will be 12 volt DC. Look for individual wiring coming out of the skin. If there is a white wire it will be the negative or common/ ground. The positive wire could be almost any color other than white. The thermostat could be wired with blue wires. How far is the furnace from the fuse panel? Maybe a PO removed the wiring. Look for a fuse holder that has nothing connected.
Help! Need new wheels for 1968 airstream Bessie1968 Wheels, Hubs & Bearings 8 06-18-2012 10:11 AM
fuses for 74 trade wind land yacht batt Electrical - Systems, Generators, Batteries & Solar 3 02-28-2012 07:18 PM
Hey Everyone! I just bought a 310 for restoration. Help needed! SteelyDan Classic Motorhomes 37 02-28-2012 01:24 AM
WBCCI number on my trailer copycat carl WBCCI Forum 3 02-27-2012 08:52 PM
Labeling Interior Panels for Restoration Darin n Bet Interior Restoration Forum 8 02-27-2012 07:50 PM
