Old 09-21-2012, 04:38 PM   #1
1966 22' Safari
Central Point , Oregon
Little Red light
Can anyone tell me about the little Red light in the rear compartment on the right side. I'm thinking this may be light when 110 power is hooked up?
Oh, 1966 safari 22'
cppilot is offline   Reply With Quote
Old 09-21-2012, 04:42 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If that light comes on when you plug in to shore power, don't touch the trailer, especially if you are standing in a water puddle. Seriously.
That is the "reverse power" indicator light. It only lights if the skin of the trailer is "live".
Old 09-21-2012, 05:01 PM   #3
1966 22' Safari
Terry, Thanks for the reply. I have never seen it on, so it's sounds like that's a good thing. How do you get the bulb out and how do you test the system?
Old 09-21-2012, 05:39 PM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Thats my Boy...a Pilot. If the red light is on....take the bulb out.
Old 09-21-2012, 05:49 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I dont think it necessariy shows the skin is hot. You would have probably figured that out already. It is supposed to indicate the outlet you are hooked up to has reversed polarity. With reversed polarity your lights and stuff will still work, but you will fry electronics.
Old 09-21-2012, 06:16 PM   #6
Well Preserved
1993 21' Sovereign
Sherman, since I personally have gotten zapped a couple of times when that light was on, I'd have to disagree with you.Now, the trailers that bit me may have had other problems that were added to by the little red light, two lights on and two zappings have led me to the above conclusion.
Old 09-21-2012, 06:50 PM   #7
Lumatic's Avatar
1993 34' Excella
Images: 16
Overlander just has a magnetic personality.
Thre's one way an outlet can be wired right. There's a bunch an outlet can be wired wrong which will light the light, I think. The most common would be postive / nuetral reversal. I don't think that will charge the skin but (again I think) nuetral/ ground reversal will. If I am wrong I hope someone who actually know what they are talking about will correct me.
But in any event you can buy an idiot proof outlet tester for cheap that will tell you if an outlet is wired correctly and if not exactly how it is miswired.
Old 09-21-2012, 06:55 PM   #8
1988 32' Excella
Robbinsville , New Jersey
The light makes connection between neutral and ground, so when the polarity is reversed the neutral is hot and the light comes on and the electricity going through the light goes to ground which is the trailer frame and shell making them hot electrically.
EDIT Not much current just enough to feel it if that is the only problem.
Old 09-21-2012, 07:58 PM   #9
r carl's Avatar
Lin , Ne
That light may turn red when the security system is set.
Old 09-21-2012, 08:45 PM   #10
Well Preserved
1993 21' Sovereign
How did you find out? It was supposed to be a secret that the little red light was a laser sight for the twin 50 caliber machine guns mounted in the rear as a tailgater deterrent.
Old 09-22-2012, 02:29 PM   #11
1967 22' Safari
Concord , California
Thanks for the info
I recently acquired a '67 Safari and was wondering about the light (as well as a million other things).
LouiesRV is offline   Reply With Quote
