Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1966 - 1968 Safari
Old 11-08-2008, 10:30 AM   #1
aircooled4's Avatar
Profile:  1971 31' Sovereign
1967 22' Safari
Pardeeville , Wisconsin
Lighting Furnace on 67
Ive looked this over quite closely...and cant seem to find how to turn on the pilot ...The gas is on at the tanks and the safety valve next to the furnace is open...no gas...help...pics might be helpful also
Jay (KB8VMO) & Sheri
Kids, cats, horses, & donkeys
WBCCI #10917
AIR #32349
aircooled4 is offline   Reply With Quote
Old 11-08-2008, 10:37 AM   #2
Lynn
Commercial Vendor
eubank's Avatar
Profile:  1967 30' Sovereign
Angel Fire , New Mexico
Most furnaces don't have a pilot.
Which furnace have you got in the rig?
Lynn
WBCCI 21043 | Blog
Monte Verde RV Park & Campground: 50% WBCCI discount
Angel Fire, New Mexico
Old 11-08-2008, 10:40 AM   #3
Mike Leary's Avatar
Profile:  On the move , To Datil, NM
No thermostat?
1983 310 Turbo Diesel Mo/Ho "Bess" 212,292 miles
Full timing since 1994
Mike Leary is offline   Reply With Quote
Old 11-08-2008, 10:40 AM   #4
Profile:  1973 31' Excella 500
Morristown , Tennessee
The first thing that I always do is make sure the gas system works at all. I would light the range. If it works, Then go to the furnace and configure to light. Hold the "pilot" button for as long as you can stand with a lighter in hand. Try to light it periodically and when it finally does, hold it for another minute so it gets hot. I'm sure there will be a lot of other recommendations but I have found this ot work after my aluminum has been sitting for any period of time. It helps to do this where it is warm and dry before getting on the road.
Joe DeFelice
1973 Excella 500
Alumin8 is offline   Reply With Quote
Old 11-08-2008, 10:40 AM   #5
aircooled4's Avatar
1967 22' Safari
this one looks to have what i assume to be a pilot...next to the thermocouple...its a Suburban...
WBCCI #10917
AIR #32349
Old 11-08-2008, 10:42 AM   #6
aircooled4's Avatar
1967 22' Safari
When the thermostat is 'on'...the blower operates and i cant get a flame to the pilot
WBCCI #10917
AIR #32349
Old 11-08-2008, 10:47 AM   #7
Lynn
Commercial Vendor
eubank's Avatar
Ok, it sounds like you've got power to the furnace. Now check to make sure that you're getting propane through the lines from the cylinders.
1. Try the (cooking) stove. If you've got no flame there, then start searching backwards toward the cylinders.
2. If you've got stovetop flame, then check to make sure that the furnace itself does not have a gas cutoff valve.
Lynn
WBCCI 21043 | Blog
Old 11-08-2008, 01:32 PM   #8
aircooled4's Avatar
1967 22' Safari
Where is the pilot button??? Im quite familiar with home gas appliance operation (stove, furnace(new and old) and water heaters...) :-)
WBCCI #10917
AIR #32349
Old 11-08-2008, 02:12 PM   #9
Lynn
Commercial Vendor
eubank's Avatar
Can you read the model number on your Suburban? Is it an NT30(X)?
Lynn
WBCCI 21043 | Blog
Old 11-08-2008, 02:41 PM   #10
aircooled4's Avatar
1967 22' Safari
It an NT 22
WBCCI #10917
AIR #32349
Old 11-08-2008, 06:40 PM   #11
Went over to the trailer today and looked at my furnace. I also get my service manual. I can't scan but will copy for you.
Operating Instructions NT-16, NT-22 and NT-32
1. To light the furnace, turn the manual valve to "off"position and wait 5 minutes. Set the thermostat at it's lowest setting. Open manual valve. Correct operating characteristics depend on this valve being positioned fully open. Never attempt to operate with valve partially closed.
2. Remove lighter hole cover. (On all models, the furnace front is not exposed, so the lighter hole must be reached by first opening the cabinet and then lifting the furnace access door. After lifting access door, remove lighter hole cover.)
3. Press reset button and hold. Insert a burning match through opening so that the flame is near the pilot. On the initial lighting the pilot may not light immediately due to air in the gas line. If such is the case, it may necessary to hold the reset button in for a minute or more before the pilot lights. When the pilot is burning, continue to hold the reset button in for approximately 30 seconds or until the pilot continues to burn when the reset button is released.
4. Replace the lighter hole cover.
5. Replace furnace panels.
6. Set thermostat at desired position.
There is much more on the sequence of normal operation, the fan switch and how it will operate even after the thermostat is satisfied to cool the unit before it shuts down. There is also an extensive section on pilot outage problems depending on which phase is associated with pilot outage: off phase, start-up phase or operating phase.
Hope this helps but if not, I'll be following this thread with interest.
Joe DeFelice
1973 Excella 500
Old 11-08-2008, 07:49 PM   #12
Profile:  Potters , Idaho
Check to make sure this is not a recalled furnace!
phoney is offline   Reply With Quote
Old 11-08-2008, 08:46 PM   #13
Lynn
Commercial Vendor
eubank's Avatar
Wow, so the NT22 does indeed have a pilot!
You know, before going toooo much further, you might want to inspect the chamber to make sure that it's not rusted or burned out.
Lynn
WBCCI 21043 | Blog
Old 11-09-2008, 01:03 AM   #14
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Put down the matches, and step away from the furnace!!!
Originally Posted by aircooled4 View Post
It an NT 22
That is a recall furnace. That means that, besides the fact it's 40 years old, it may have a combustion problem that may kill you. Read more here:
Infamous Suburb.NT-22 "recall" furnace issues!
(No Longer at Inland RV)
Track Lighting & Lighting Ideas ClassicRides Electrical - Systems, Generators, Batteries & Solar 8 08-29-2008 03:03 PM
Lighting pilots and testing fridge and furnace sp635 General Repair Forum 3 11-02-2007 02:10 PM
DC Lighting Over59 Electrical - Systems, Generators, Batteries & Solar 48 04-03-2005 06:51 PM
Lighting 87MH Electrical - Systems, Generators, Batteries & Solar 0 07-31-2003 07:18 PM
