Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1966 - 1968 Safari
Old 11-09-2008, 01:06 AM   #15
aircooled4's Avatar
Profile:  1971 31' Sovereign
1967 22' Safari
Pardeeville , Wisconsin
Well...Thanks for the instructions...after looking mine over more thoroughly I came to exactly the same conclusion of how to light it as you instructed...The knob for my 'pilot button' was missing...hence some confusion...Im guessing now i need a new/different regulator....I have plenty of gas, nothing is getting ot the stove either...i even loosened the brass fitting where it meets the manifold on the cooktop...nothing...SO...anyone have an extra regulator laying around? :-)
Jay (KB8VMO) & Sheri
Kids, cats, horses, & donkeys
WBCCI #10917
AIR #32349
aircooled4 is offline   Reply With Quote
Old 11-09-2008, 01:08 AM   #16
aircooled4's Avatar
1967 22' Safari
My original intent was to just use it enough to allow me to work in it this winter...Definatly going to replace it sooner than later..maybe MUCH sooner!
WBCCI #10917
AIR #32349
Old 11-09-2008, 08:05 AM   #17
Profile:  1973 31' Excella 500
Morristown , Tennessee
Wow, thanks to the moderator for this choice bit of information - and humor (LOL). I am not clear what the problem is with these units but will certainly find out. Is it just a matter of rust or poor design that creates the danger?
Hope someone can shed some light.
Joe DeFelice
1973 Excella 500
Alumin8 is offline   Reply With Quote
Old 11-09-2008, 08:19 AM   #18
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
The recall had to do with a crossover tube on the back side of the furnace that was found to be failing. This website has a lot of information about the recall: Suburban furnace
Richard
Charter Member Four Corners Unit
Old 11-09-2008, 08:53 AM   #19
Thanks for the sight. It looks like the only way to be sure is to remove the unit. I was hoping to avoid that but "what the heck". Most of the interior is already out and it might be the right time for a new furnace and replace the Univolt.
Joe DeFelice
1973 Excella 500
Old 11-09-2008, 10:06 AM   #20
cameront120's Avatar
Profile:  1972 25' Tradewind
Mine is the same model and it works brilliantly. I'd recommend a propane and CO alarm for your trailer.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 11-09-2008, 01:57 PM   #21
That's not a big problem since I have a CO detector for my plane that can function when on the ground as well. NOw just procure a paropane sensor and I'm home free.
Joe DeFelice
1973 Excella 500
Old 11-09-2008, 04:20 PM   #22
Profile:  Potters , Idaho
recall
I have the same furnace and found the recall has to do with the hose used between the heat chamber and the fan. It is a short piece of heavy duty 2 1/2" or 3" about 1 1/4 long. I think TOMW has a good pic on his 1967 overlander site that shows the recall stove and the good one. Check the orfice on the propane supply and blow out with compressed air only. DO NOT SHOVE A NEEDLE IN THE HOLE OR IT IS CAPUT.
phoney is offline   Reply With Quote
Track Lighting & Lighting Ideas ClassicRides Electrical - Systems, Generators, Batteries & Solar 8 08-29-2008 03:03 PM
Lighting pilots and testing fridge and furnace sp635 General Repair Forum 3 11-02-2007 02:10 PM
DC Lighting Over59 Electrical - Systems, Generators, Batteries & Solar 48 04-03-2005 06:51 PM
Lighting 87MH Electrical - Systems, Generators, Batteries & Solar 0 07-31-2003 07:18 PM
