Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1966 - 1968 Safari
Old 09-22-2008, 08:58 AM   #1
Profile:  pagosa springs , Colorado
Kitchen Sink Covers?
Anyone know where to find these for a 68' Safari?
gc24 is offline   Reply With Quote
Old 09-22-2008, 03:55 PM   #2
mustang's Avatar
Profile:  1986 31' Sovereign
Kent , Ohio
I have extras. What color. Mine are greenish for double sink.
They seem easy enought to make. Glue a peice of formica to wood.
mustang is offline   Reply With Quote
Old 09-22-2008, 05:13 PM   #3
Isadora's Avatar
Profile:  1976 Argosy 24
Joplin , Missouri
I think I would make them. In fact, I am thinking about replacing mine cut out of wood cutting boards. It would be really nice to have cutting boards in my kitchen.
Jim and Sandy
"To know is nothing at all. To imagine, is everything." --Albert Einstein
Isadora is offline   Reply With Quote
Old 09-22-2008, 09:05 PM   #4
Thanks Mustang. If you are willing to send them along, I would appreciate it. Green is fine
Old 09-22-2008, 09:39 PM   #5
Foiled Again's Avatar
Virginia Beach , Virginia
New Ones
New ones are made out of high impact plastic. Ideal for cutting boards. I flip mino over and use the bottom side just so the top won't get scratched.
BTW. Who really uses them? I wanted a stove cover - now I barely remember to use it. Most of the time my sink covers are tucked in the cabinet. Only come out when company is coming.
Paula
Today is a gift. That's why they call it "the present"
Foiled Again is online now   Reply With Quote
Old 09-22-2008, 11:05 PM   #6
BIGED52's Avatar
Profile:  1967 22' Safari
MILAN , Illinois
I took the butcherblock top off of an old KitchenAid dish washer. I cut it in half, planed it down to clean surfaces top and bottom, and routered the bottom to fit the double sink bowls on each half. When sanded and oiled it completely covers the sink area from raised edges all around except where it was cut out for the faucet set. It lines up in the center to form one complete cutting board cover and looks/works great. hope this helps... Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004
AIR#7110
"My tire was thumping, I thought it was flat!
When I looked at the tire... I noticed your CAT!"
Burma Shave
BIGED52 is offline   Reply With Quote
Old 09-22-2008, 11:33 PM   #7
Ifihadtime's Avatar
Profile:  1981 27' Excella II
Lynnwood , Washington
If you plan to make them make from wood be sure you put laminate on both sides otherwise you will end up with a serving bowl. Don't ask how I know
Ron
81 Excella II "McTwinkie"
I am always doing that which I can not do, in order that I may learn how to do it.
Ifihadtime is offline   Reply With Quote
Old 09-25-2008, 04:06 PM   #8
No, we're not there yet!
Maddoxx2's Avatar
Profile:  1966 22' Safari
Acworth , Georgia
Mine were missing also but I found some bamboo cutting boards at Lowes and cut them to fit. They really look great.
Maddoxx2 is offline   Reply With Quote
Old 11-28-2008, 07:06 PM   #9
AZ-JH's Avatar
Peoria , Arizona
I wish the sink covers/cutting board that came with the unit matched the countertops. We have midnight sun interior, but the sink covers are a stark white.
AZ-JH is offline   Reply With Quote
Old 11-28-2008, 09:41 PM   #10
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Funny this topic should come up. I made a cover for the one sink out of some exotic bird's eye maple and was getting ready to make the second one when I found the wife had decided to wash the first one in the dishwasher. Not a good idea. Back to square one.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 11-28-2008, 09:51 PM   #11
Got the same thing. The plastic is food grade cutting board material. I think it might only come in white. They do eliminate the need to carry extra cutting boards, however they are NOT designed to withstand really hot objects like pots or pans. I found out the hard way, but fortunately it happened with a cheap Wal-mart board, not the actual sink cover.
Paula
Old 11-28-2008, 10:18 PM   #12
Distantdrummer's Avatar
Profile:  1975 31' Sovereign
, various
What holds those babies down while in transit?
Distantdrummer is offline   Reply With Quote
Old 11-28-2008, 10:47 PM   #13
SteSpot's Avatar
Profile:  1968 28' Ambassador
Venice , California
Hold downs
New axles.....pj
Suite Spot
WBCCI # 22353 Air#13593
1968 28'Ambassador
SteSpot is offline   Reply With Quote
Old 11-28-2008, 10:57 PM   #14
catson4's Avatar
Profile:  1991 34' Limited
Port Orchard , Washington
Thumbs up Corian sink covers cheap
Go to a company that installs Corian counter tops. They will have some of the cut outs from installing sinks in houses. You can use a carbide tipped blade and cut to any size you want. A router with good bits will trim to the EXACT size and smooth the edges.. Drill a "finger lift hole" in one corner and finnish it with the router.
If your sink is "TOP" mounted on the counter, then there is a glue ( available at the same dealer) for gluing TWO pieces together. Cut one that fits inside you sink and the top piece to the size you want. Finnish with the same process as above.
They will stay in place in transit because of the weight. Any way they do in my 34' Limited.
Claude
One bazillion fish
1991 34' 60th Aniversary Limited Edition #008
2007 Chevy 2500 HD Duramax/Allison
One big parade float & a 40' Wells Cargo 5th wheel trlr.
"Wake each morning & Smile at the GREAT DAY you about to experience"
www.catson4ponds.com
catson4 is offline   Reply With Quote
Peeling wallpaper by the kitchen sink caadoptees Cabinets, Counter Tops & Furnishings 26 12-22-2008 08:57 AM
fixing a 71 kitchen sink drain Lumatic Sinks, Showers & Toilets 3 07-10-2008 09:44 PM
Refinishing the kitchen sink 48-remi Sinks, Showers & Toilets 13 05-09-2008 10:06 PM
need new kitchen sink shantz Sinks, Showers & Toilets 4 03-24-2008 09:48 PM
Kitchen sink lites FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-15-2002 11:17 PM
