02-01-2012, 07:24 PM
#99
Hatari
1967 22' Safari
Gainesville
, Georgia
All,
I have the wire cloth in the floor but the vent (access door) is a Dometic part number and is totally aligned with where the OEM Fridge was and appeared to be for servicing or dealing with the gas/electrics. I can't detect that there was damage in this area of the trailer and the Dometic fridge was in it's original location and the PO said worked (I didn't try it though and it's long gone). At any rate, I'm interested in keeping the access door (but also making it presentable) for my new AC / Fridge plans...It will serve a few purposes. If I have to, I belive I can resotre mine to decent aesthetic condition. The louvers are functional and very cool (as in 60's hot rods). I'll share the AC plans/idea soon.
Jack
02-01-2012, 07:26 PM
#100
Hatari
1967 22' Safari
Gainesville
, Georgia
See the vent location here...
Jack
02-02-2012, 01:57 AM
#101
1967 22' Safari
MILAN
Vent Grill
Jack, After looking thru photos @ VintageAirstream.com I may have found where your vent cover came from. If you go to the model archives then photos for 1962 model trailers (I looked at Safari & Flying Cloud). In the first set of Safari photos on the left side of the page using the scroll bar scroll down to the curbside view (approx.) 6 pics and it shows two louvered vents one above the other to the left of the main entry door. My guess is that a PO had an issue with the small access door on the '67 and did a DIY update to the older style larger louvered vent access. At least you may be able to track down a donor trailer somewhere in a RV salvage yard or thru the forums that would sell you that part. At least you have the part/assembly number so you can verify it is the same as what you already have before you buy one from someone. I always hate buying sight unseen or as my granny would say "A Pig In A Poke"!!! Hope this helps a little. Gee Whiz... This was like watching a History Detectives program episode on Public Television. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004
AIR#7110
"My tire was thumping, I thought it was flat!
When I looked at the tire... I noticed your CAT!"
Burma Shave
02-02-2012, 07:02 AM
#102
1971 21' Globetrotter
Arvada
Just a suggestion here, but I had louvers stamped at a Hot Rod shop several years ago for another project (59 Willys Wagon) and the price was quite reasonable. However you would have to use either 5052 or 3003 aluminum because 2024-T3 will crack with louver dies.
02-02-2012, 12:24 PM
#103
1967 22' Safari
MILAN
That's the Ticket!
Jack, This just might be the best way to go! New Aluminum and your old insert grill for the pattern... What a helpful suggestion by Aerowood! I bet this could get your vent updated with the smallest amount of searching and better result than looking all over for a donor grill. Ed
AIR#7110
Burma Shave
02-03-2012, 05:32 PM
#104
Hatari
1967 22' Safari
Gainesville
, Georgia
Actually, this was an option I was considering...just need to find a shop in the Atlanta area that can stamp louvers...
I do want to have the access door here in working (and good aesthetic) condition.
Thanks for the suggestion. I'll be surfing for a hot rod shop.
Jack
02-04-2012, 04:58 AM
#105
Hatari
1967 22' Safari
Gainesville
, Georgia
Jack
And, I meant to say thanks to Aerowood for the suggestion. I am friends with a guy here who does custom car painting. Good chance he may know someone who could do the louvers. Will keep you posted.
Jack
02-04-2012, 06:54 AM
#106
1968 24' Tradewind
1964 24' Tradewind
1955 22' Safari
holly springs
, Georgia
There is a place in Marietta on williams dr. called Metal Supermarket, they may be able to help. Actually you dont need louvers if you have a vent in the floor and one on the roof you can just use an access door, which you can probably find used or get from inland rv.
Kevin
02-04-2012, 07:00 AM
#107
1968 24' Tradewind
Oxford,
, Mississippi
Jack,
My 68 has hole in the floor with hardware cloth on the floor and on the belly pan.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
TAC-MS-3
KF5IMA
02-05-2012, 04:57 PM
#108
Hatari
1967 22' Safari
Gainesville
, Georgia
Finished wiring in the electric brakes today. Also trimmed/located and temporarily mounted the new inner wheel wells. I think I found someone to make the louvered access cover which I am very happy about...not sure I'd find one in any better condition than mine. I need the ventilation that this cover will allow for the new heat/AC unit...I'll explain this soon when I can show some photos of the idea/plan. Smoked some baby backs today while working. It was 70 and sunny in N. GA today. Perfect AS working weather.
Jack
03-01-2012, 06:22 PM
#109
Hatari
1967 22' Safari
Gainesville
, Georgia
Not from a hot rod shop but a very talented local sheet metal shop...the new louvered cover replacing the damaged and fatigued Dometic uint shown in previous thread.
03-01-2012, 10:50 PM
#110
1967 22' Safari
MILAN
Sweeeeeet!
Jack, That new louvered vent cover looks Great! Are you planning to replace the old (rusted) screws that hold the trim around it with stainless steel ones? If so enlarge the holes slightly to remove any dissimilar metals issues with the holes in your skin and get new SS screws from Fastenal. They will have any size and style SS screws you will need. Last time I was in my local store they even had shear-off screws that once the drive head has done its job to tighten the cover in place you snap them off and the remaining head of the screw looks like large rivets and (bonus) won't rust or cause corrosion to the aluminum skin where they are screwed into. I have some Stainless Steel filter material that is about 1/2 inch thick and looks like steel wool mesh in a 2 foot wide roll that I am planning to use to mount inside the Stainless Steel hardware cloth to act as a bug and critter barrier. I am having a aluminum c channel square frame made to (load) the mesh into so it will not be able to move around in the belly pan and will have it mounted (Pop Riveted) to the belly pan skin. It will really reduce the amount of bugs and critters that were able to go right thru the old Galvanized hardware cloth. I can tell you there were a lot of bugs and critters that most likely got into the belly pan and then into the trailer thru the old floor vent and belly pan. I cleaned up about 40+ years of them since I have owned the trailer. Never thought at first that they were coming in thru the fresh air vent. Once the new hardware cloth and the mesh are installed it should be a much cleaner air flow to the gas appliances. I have to stop being long winded. Waiting to see your further progress in this thread. Ed
AIR#7110
Burma Shave
03-02-2012, 05:16 PM
#111
Hatari
1967 22' Safari
Gainesville
, Georgia
Ed, thanks... I thought the cover came out nice too. I'm lucky to have a good metal guy nearby. He also made my wheelwells. And yes, I will not only replace the rusty screws, but also the trim / frame around the cover also. Ultimately, the exterior will be polished and so will these parts. I like the sound of the shear screws and will look for them. I plan to buy the correct rivet kit to install and shave OEM type rivets soon. I am at a point that I can't begin the subfloor reinstallation until I've finished removing the old roof AC and re-seal all the seams. It does take on some water when the rain comes hard. So, I will be putting scaffolding up hopefully this weekend to be able to work on top.
Where did you get the stainless wool you mentioned? I need to put some on the inside of that cover and a few other places.
Jack
03-03-2012, 02:12 AM
#112
1967 22' Safari
MILAN
Jack, Best bet on the stainless wool filter material is a heating cooling contractor or supply house. I work with Insulators at nuke plants and they use it in vents for bug and critter barrier behind the vent panels for A/C and Heat units. My Heat and Frost Insulators Local is for Asbestos removal so I see these Guys often. I am due to work @ Quad Cities Nuclear this month. I will find out the actual name for the product and post it here for you. Ed
AIR#7110
Burma Shave
| Thread Tools |
| Display Modes |
