Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1966 - 1968 Safari
Old 04-03-2008, 08:30 PM   #1
1966-safari
Profile:  1966 22' Safari
Boca Raton , Florida
I Need a picture of the 12 volt panel / wiring
I Need a picture of the 12 volt panel / wiring.
last owner disconnected a few too many wires.
Thanks!
1966-safari is offline   Reply With Quote
Old 04-03-2008, 09:28 PM   #2
crispyboy
crispyboy's Avatar
Profile:  1981 22' Excella II
alexandria , Kentucky
I recently reworked my 12 volt dc panel. Here is an old and new photo.
crispyboy is offline   Reply With Quote
Old 04-03-2008, 11:38 PM   #3
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
Looks like the new upper fuse left side has been getting hot?
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 04-04-2008, 11:59 AM   #4
crispyboy
crispyboy's Avatar
I have powered the board up several times and it works perfectly. THERE ARE NO BARE HOT WIRES OUTSIDE THE BLACK ENCLOSURE BOX. If your looking at the bare heavy guaged wire in the upper left hand corner - that is the ground. I have not hooked up the negative wire from the battery yet. Both the positive and negative wires are fused that are between the battery and the panel just like the original. The positive wire coming from the battery is going to the fuse and is protected inside the box. The wires are the same color as I went through my salvage box in the garage and found a good battery cable that was long enough to use for both the positive and negative.
Also you cannot see the back of the panel where the positive and negative wires are coming from the converter. These wires are connected to lugs on the rear of the panel (the same lug you see in the picture goes all the way through the panel).
Old 04-04-2008, 02:42 PM   #5
Toldfield
Tom O
Toldfield's Avatar
Profile:  1966 17' Caravel
1968 26' Overlander
Altadena , California
What brand/where did you get the panel?
"Badges? We ain't got no badges. We don't need no badges. I don't have to show you any stinking badges!"
Toldfield is offline   Reply With Quote
Old 04-04-2008, 02:58 PM   #6
1966-safari
Thanks for the pictures here is what mine looks like...
I have two blue wires that are still in need of proper placement.
I am thinking they both are attached to the same post?
Do the two unattached blue wires attach to the bottom post where the connected blue is?
If I am incorrect please let me know.
Thank you!
Christopher
Old 04-04-2008, 03:03 PM   #7
crispyboy
crispyboy's Avatar
The brand is Parallax. I purchased this from a airforums board member.
BestConverter - Converters, Inverters, Electrical Supplies, Electronics
12 volt DC wiring? piratesteve Electrical - Systems, Generators, Batteries & Solar 6 10-06-2006 12:00 AM
What size fuse for 12-volt panel? paddy79 Electrical - Systems, Generators, Batteries & Solar 4 05-23-2004 09:39 AM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 01:04 AM
12 volt Wiring Texas'68 Electrical - Systems, Generators, Batteries & Solar 2 09-17-2003 07:12 AM
Picture series-exterior panel replacement PeterH-79MH Ribs, Skins & Rivets 9 06-03-2002 05:51 PM
